cutoff levels
Discussion in 'Questions To Truckers From The General Public' started by pank83, Sep 27, 2011.
  1. pank83
    pank83 Light Load Member
    112
    54
    May 19, 2011
    Lawrenceville, Ga
    When it comes down to a drug screening what exactly is a "cutoff level"? And does DOT or the trucking industry have a set/standard level across the board? I have did some reading on this but I honestly don't understand.
  3. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,179
    Apr 20, 2011
    Dahlonega, GA
    The level is 0.0, test anything above that, driving truck isn't for you.
  4. THBatMan8
    THBatMan8 Road Train Member
    1,478
    469
    Feb 13, 2011
    Wherever I park
    Each state's DOT has their own limits, but company policy on mainstream carriers is zero tolerance.
  5. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Whooot ? You think this is Canada ??
  6. GOV'T_Trucker
    GOV'T_Trucker Heavy Load Member
    782
    668
    May 28, 2011
    Canada doesn't do drug testing.. Unless your going into the US...
    I wonder why this is??
  7. hup
    hup Medium Load Member
    592
    209
    Oct 19, 2010
    Missoula, MT
    because the USA has figured out how to cop freedom from its people without them complaining, Canada hasn't caught on yet..
    Dominick253 Thanks this.
  8. wis bang
    wis bang Road Train Member
    3,414
    4,047
    Jan 12, 2011
    Levittown, PA
    Cut off levels is the amount needed to trip the first test that indicates the presence of a controlled substance. Once that is reached they do a Mass spectrograph to determine the drug.
    Back when this all started the cutoff level for POT was 100 nanograms per ml. they decided after a short time to drop the cutoff to 50 ng/ml and had a dramatic increase in POT positives.
    AFAIK the cut off have not changes since.
  9. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    wis bang is correct. Companies know absolutely nothing about amounts. They just know whether you tested positive or negative. Only the lab and MRO knows the amounts.
    To eliminate false positives, they have created cutoff levels when testing to satisfy "without a doubt" results. Stuff like Heroin, poppyseeds will show trace amounts. THC, Advil will show trace amounts. So they use cutoff levels to eliminate them.
    A GC-MS burns the sample as the machine temperature increases. Every substance on earth burns at a certain temperature and a certain length of time. The machine graphs this. By known samples called "standards" they can figure out what is what on the graph. The machines even print out the results with numbered measurements.
    Let's say where pot is suppose to spike, instead of spiking 1 inch on the graph, it just spikes a 1/4 inch, you might pass depending what the cutoff level is. They might figure 1/2" or a certain amount on the printout. It's a little more complicated, but that's just to give you an idea.
    Like wis bang said, this test is expensive. They first do a cheap chemical reaction test. You test negative, test over. Test positive, off to the GC-MS test for a back up confirmation. That's why when you give them a urine sample, they use two containers.
    I got to use a GC-MS at a chemical plant job I had. Basically we heated chemicals in a reactor. We used the GC-MS to tell when the reaction process was done. The machine has many uses. I think back in the 80's I was told they cost around $18K. they ain't cheap.
  10. Trucking Popeye
    Trucking Popeye Light Load Member
    184
    106
    Sep 22, 2011
    Shepherdsville, KY
    False reports on drug screens? This website http://www.passyourdrugtest.com/false-positives.htm has a ton of regular prescriptions and over the counter drugs that cause false positives. Is this true or are they just trying to sell their "scam the drug test" items?
    My reason for concern is that I have been taking the antibiotic "Cipro" recently and there is a big write up saying that it can cause you to test positive for opiates (see http://www.passyourdrugtest.com/12-25-2001-news.htm ).
    Thanks for any info you can give.
  11. Black_379
    Black_379 Light Load Member
    141
    65
    Aug 15, 2011
    If you test positive the lab Dr will call you. This is why you have to put a day and evening phone number on the form. They will ask you if you are on any meds. They know what can cause false positives and what can't. After you inform them of what you are taking the will call your pharmacy to confirm the prescription is legit. I take a pill for acid reflux that they say can cause a false psoitive but I've never had an issue in 5 yrs taking it.
    CondoCruiser and Trucking Popeye Thank this.
