D I need a cdl to do hotshot?
Discussion in 'Questions To Truckers From The General Public' started by cornelas19, Apr 19, 2014.
  1. cornelas19
    cornelas19 Bobtail Member
    Hello there guys, I was wondering if I need my CDL to do hotshot for a company. (Victory Transport) I've been working in the warehouse for the past 5 years. Supervisor at the moment but decided to get into trucking for more money. I want to get a Dodge Ram 3500HD. (Should I get it with flatbed or regular bed?) I 'm only going to be hauling 1 or 2 skids no more than 3k lbs with no trailer. Will i need a cdl for this? I live in Texas and will sometimes require to go out of town to different states. They are offering me 65% per load. Think it would be worth it? All advices would be greatly appreciated. Be safe out there and God Bless.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    If the vehicle is rated more than 26,000 lbs GVWR then you need a CDL or any weight if you decide to be hazmat qualified. Many hotshots run hazmat. Another consideration is if you pull a trailer with greater than a 10,000 lb GVWR which brings your GCWR above 26,000 lbs then you need a CDL. I'm not sure but I don't think a 3500HD is capable of doing that. At a minimum any vehicle over 10,000 lbs you need a DOT medical card.
  4. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Better check the regulations closely.
    This link gives some information on the cdl with hazmat.
    http://expeditenow.com/truckingblogs/395-can-you-haul-hazmat-without-an-endorsement.html
    383.5 Hazardous materials means any material that has been designated as hazardous under 49 U.S.C. 5103 and is required to be placarded under subpart F of 49 CFR part 172 or any quantity of a material listed as a select agent or toxin in 42 CFR part 73.
    So, you need a CDL with a HAZMAT endorsement to haul hazardous material, but only that material which is on the Table of Hazardous Material and which requires placarding. If it doesn’t require placarding, you don’t need a CDL, and you don’t need the endorsement. It’s really that simple.
    - See more at: http://expeditenow.com/truckingblog...hout-an-endorsement.html#sthash.F1Lo2FAg.dpuf
  5. cornelas19
    So would I be good to go with my regular class c license to do hotshot in a 3500HD truck? I know those truck weigh about 11k lbs. So if I take a load that weighs 3k lbs, that would be 14k-15k lbs when loaded with truck weight.
