I have a d12c , 2001 , 465hp. I have set my intake valves. Need to do exh. Valves.
Does anyone know the tool required, the part number and where can I buy it online. My local dealer won't sell me the tool. Also is there a diagram to set injectors.
Thanks
D12 valve set tool
Discussion in 'Volvo Forum' started by Frank5229, Aug 19, 2012.
is it engine with VEB? if yes, you need 2-3 mm wire to bleed valve lifters. really hydrolic ex. valves usually do not require ajutment.
king Q Thanks this. -
Just a regular d12 with jakes
Jakes is actually a brand name.
On the Volvo it is called VEB so do what Pablo says.Frank5229 Thanks this. -
Jake brake brand is not registed in EU so they call as they want, Volvo - VEB, MB - engine compression brake.... anyway the same thing
