D13 hard start issue
Discussion in 'Volvo Forum' started by jrotra, Feb 28, 2017.
  1. jrotra
    jrotra Light Load Member
    85
    23
    May 27, 2010
    Inverness , Florida
    Any ideas? 2016 780 D13 90,000 miles . Dealer replaced crank position sensor camshaft sensor , batteries, checked injectors said OK said they found intermittent short in wiring harness
    Still have a intermittent hard start,cranks but does not fire , usually when batteries have been drained slightly,but not always.this am it only set for 10 minutes no drain at all.
  3. Dave_in_AZ
    382,009
    So did they replace the harness?
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    does it help if you try to hit the primer pump for about 10 times before you start sometimes the return check valve gets debris
    KB3MMX Thanks this.
  5. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Could also be a leak in the fuel system letting air in so the fuel drains back to the tanks. Usually an injector or a filter O-ring.
    jrotra Thanks this.
  6. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    most likely an injector will cause this kind of issue i have found broken injectors before and everything came back perfect when i took them off the injector was broke in half had that happen with d13 twice
    ReeferOhio, KB3MMX and jrotra Thank this.
  7. jrotra
    85
    23
    May 27, 2010
    Inverness , Florida
    Have not tried it,but will, thanks.
  8. jrotra
    85
    23
    May 27, 2010
    Inverness , Florida
    Only repaired
  9. Dave_in_AZ
    382,009
    Crank or cam sensors wear out after a long time. Fault in the wiring harness I'd believe. I already hate the dealer you took it to, cause I don't think they know their stuff. We have the number 1 in the nation here in Phoenix.
    I'd bet that harness is wreaking havoc with a low resistance fault on the ecm some place.
    KB3MMX Thanks this.
  10. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Which dealer so I can avoid??
    Thanks Dave !
  11. jrotra
    85
    23
    May 27, 2010
    Inverness , Florida
    Orlando FL Volvo
    KB3MMX Thanks this.
