d13 injector cups
Discussion in 'Volvo Forum' started by letsgofast, Sep 18, 2017.
  1. letsgofast
    letsgofast Bobtail Member
    25
    8
    May 9, 2013
    Does anyone know the torque spec for the injector hold down bolts when replacing both injectors and stainless steel injector cups?
  3. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    (1) 20 ft. lb (2) +180 degrees (3)back off till hand tight (4) 20 ft.lb again (5) +90 degrees
    Make sure that you use new bolts.
    letsgofast Thanks this.
  4. Bike rider
    Bike rider Bobtail Member
    48
    33
    Apr 11, 2016
    from the service manual.
    When installing the cup:
    Tighten the bolt to 80 ± 5 Nm (60 ± 4 ft-lb)
    Then when installing the injector:
    Note: If available, use an electronic digital torque wrench for the tightening procedure.
    Install NEW injector hold down bolt and follow five step tightening procedure:
    1. Tighten 20 +5 Nm (15 +4 ft-lb).
    2. Tighten 180 ±5 degrees angle of tightening.
    3. Loosen the hold down bolt until torque is 10 to 15 Nm (7.0 to 11.0 ft-lb).
    Note: This should be achieved by loosening with an angle of 100-110 degrees. Do not completely loosen the bolt to prevent components from moving after the previous seating process.
    4. Tighten 25 +5 Nm (18 +4 ft-lb).
    5. Tighten 90 ±5 degrees angle of tightening.
    QUALITYTRUCK and letsgofast Thank this.
  5. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    the only thing i would suggest instead of the 90 put at 120 degrees and make sure you use the carbon paste that comes in the injector kit.
    QUALITYTRUCK Thanks this.
