I have a 2007 vt 880 d16 625. 18 speed
When I am climbing big hills with a good load my oil pressure will drop to the point of shutting down the truck unless I keep rpm over 1350 ish. I have been watching the oil temp and it will get up to 118 119 c. Which will also give me a warning.
I am running 15 40 Dino oil. I get regular oil samples done with never anything to report. I am about 7000 kilometres to oilchange time. Truck never drops off of the safe range on dipstick between oil changes.
Truck has approx 800000 Kms on it
Any thoughts?
D16 low oil pressure when going up big hills
Discussion in 'Volvo Forum' started by Morkable, Jun 30, 2016.
2001 Volvo 770 Cummins N14
Few years ago I had a low oil pressure warning, my mechanic was pulling his hair out change and oil pumps trying to figure out what the problem was.
We eventually found the problem in the dash, at a loose wire on the circuitboard where the oil pressure gauge is.
Have someone test your oil pressure with mechanical gauge on the engine separate from your dash gauge.Danny707 Thanks this. -
Good call
I have a friend who went through this. Up hill and stop lights his oil pressure would drop a lot. Come to find out his dip stick was never calibrated. He bought the truck used and it was not the dip stick that came with the truck when new.
He bought an after market dip stick new. It was long and no markings. They pulled up the specs on how much oil goes in the truck. They changed the oil and put new oil in minus 2 gallons and marked the stick. Put in one more gallon and marked the stick then cut off some excess. -
So was he low on oil before?
Gotcha
So, go get your oil changed. Pull out your manual and see how much oil your engine takes WITH new oil filter. Tell them to put exactly that much in. Take dipstick out and see where level is. If stick is off then take a file and make a new mark on the dipstick.
You can also tell them to stop short by 3 gallons and make a mark. Then 2 then 1. -
Check Posibility of Adding an manual Oil Psi gauge for testing purposes or try to change oil psi sensor to eliminate that out of the equation. The other thing i have for you is that did anyone recently work on the top end of the engine, volvo has a engine brake valve with two o rings on top if one of those o rings breaks than it will drop the oil psi to half of what it is supposed to be. this is the kind of issue you want to get figured out sooner rather than later because the aftermath from this is quiet extensive.
QUALITYTRUCK Thanks this. -
I did just get the valves set. And while they were in there they changed the o-rings for the engine brake.
Question, what should the oil pressure be at normally? Right now at highway speed on level ground it is at around 55KB3MMX Thanks this.
