DAC report question
Discussion in 'Questions From New Drivers' started by wannabe, Mar 1, 2017.
  1. wannabe
    wannabe Bobtail Member
    13
    Jun 12, 2006
    Hey, I have a question about DAC reports. About a year ago I went out with a trainer but had to leave after a few days. I had an emergency at home and had to leave abruptly. My question is, do you think this will be reported to my DAC report? I don't know whether or not to bring up this event when applying for a job today?
  3. Chinatown
    Chinatown Road Train Member
    75,031
    171,091
    Aug 28, 2011
    Henderson, NV & Orient
    You'll be asked why you left the job, so just say you quit due to family emergency. Companies know any company you've ever worked for, so don't try to hide it.
  4. wannabe
    13
    Jun 12, 2006
    Thanks, much appreciated
  5. Eddiec
    Eddiec Road Train Member
    2,248
    3,453
    Feb 2, 2015
    Contact Hire Right and request a copy of your report. DAC is owned by Hire Right.
    tscottme Thanks this.
  6. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Even if you don't need to put reason for leaving you will need to put the date you started and date you left so the recruiter may ask why you didn't stay long.But none the less this won't tarnish your chances finding a job.
  7. The Greaseman
    The Greaseman Bobtail Member
    6
    Feb 17, 2017
    It depends on how you handled the situation most likely. But since you weren't in charge of the truck it probably won't be anything as bad as a Abandoned Load or anything
  8. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    You quit due to family emergency. You went home. Therefore you quit.
    That is your story and you are sticking with it.
    It's possible it will get reported. The sticker is this. If you were alone with your assigned truck AND under a load dispatch, and up and quit and went home, they will write DAC for abandonment of truck and load. That will ban you from being hired potentially three years. They can if they really wanted to destroy you, keep adding stuff to the DAC which then you have to dispute and wrestle with every single employer for 10 years of your life. But you may not be allowed to drive a big truck again for a while if ever.
  10. x1Heavy
    34,017
    42,137
    Mar 5, 2016
    Or find a employer running heavy trucks without a DAC anywhere...
  11. moloko
    moloko Road Train Member
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    Don't forget, that you may dispute the fact that you even worked for this company on your DAC report, with HireRight. This doesn't mean you're omitting it, it just means prospective employers will not see it on your DAC report. If that company doesn't respond--and they might not if they're big enough--HireRight deletes the information. I've done it before.
    But always be upfront about DOT employment. It's the law, and if you conceal it, it just makes you look like you're hiding a positive drug test or an at-fault accident. An employer will respect your honesty if you haven't hopped jobs every 3 months since then. Sometimes, it just doesn't work out at a job, for personal reasons or because life just happens.
