DAC REPORT
Discussion in 'Experienced Truckers' Advice' started by SmoothtruckerArt, Sep 11, 2017.
  1. SmoothtruckerArt
    SmoothtruckerArt Light Load Member
    83
    13
    Nov 2, 2016
    I got into an accident this time last year I just found out the company put it on my DAC report which I'm not surprised I hit a guard rail and had to be towed to a shop the question is how do I fight it the cops came but didn't write a report or give a ticket my concern is the company gave me a violation of reckless driving even though no report or citation was given im trying to switch companies but have been denied already by one because of this
  3. MachoCyclone
    MachoCyclone Road Train Member
    4,417
    3,907
    Jun 13, 2012
    Texas
    What companies report to DAC has nothing to do with police reports or tickets issued. It's a history of your driving performance while employed with a carrier not your MVR.
    In the company eye, you hitting a guard rail is preventable weather it was caused by reckless driving or any other reason. People just don't hit guard rails cause they are driving safely.
    I don't think you can have it removed, but you can add your comments to the company report.
    In the end, you screwed up and now have to deal with the consequences.
    jeff18 and pattyj Thank this.
  4. snowwy
    snowwy Road Train Member
    20,591
    13,310
    Jul 6, 2009
    Work for companies that don't use dac and you won't have to worry about it.
    Think local. But if you insist on doing long haul. Then don't work for megas.
    RedKnight and jeff18 Thank this.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    the only thing you can do is submit a rebuttal to DAC, maybe you hit the guard rail in bad weather? maybe someone forced you off the road?
    other than that, a company can DAC you for an accident or incident without a police report, or ticket. the mere fact it had to be towed away was enough for them to DAC you.
    this won't necessarily prevent you from getting another job, it just may slow you down a bit in finding one.this will be tough as you were DAC'd for RECKLESS driving....
    best of luck
    pattyj Thanks this.
  6. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    As mentioned, you can file a grievance/rebuttal (and most likely lose). Or do nothing, and get the same result. Find a company that doesn't use DAC....it's not hard....if they DO use DAC, they have to disclose it on the application, and have you sign for them to do the background check via DAC/HireRight.
  7. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    with a rebuttal one does not necessarily win or lose, it's a matter of having your say in what happened, rather than to sit silently and go thru the job denials in the future.
    many times too, DAC will contact the employer for thier response, sometimes the black mark is removed, sometimes not.
    much like a ticket one gets, he/she is ALWAYS advised to "fight it"....
    if you do not "fight it" in this case a rebuttal, it stays on the DAC file unchallenged.
    been there, done that.
  8. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    As have I.....and I won.
    The ONLY way it goes away, is if you win. No company gives a rat's behind that you contested it, unless you win (and it's not there to see). A "record" of your rebuttal means nothing.
  9. MachoCyclone
    4,417
    3,907
    Jun 13, 2012
    Texas
    Even if he applies at a company that doesn't use DAC; he still has to list them as a previous employer. And if the potential employer contacts the previous employer and they tell thme he can still be denied employment.
    So, applying at a non DAC company won't guarantee a job.
  10. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    well i have had it both ways. i had misinformation removed, i have had alleged accidents removed, and i have rebuttaled other crap. whether or not a new employer gives a rat's butt as you say, is immaterial. it is there as your way of saying "i got my 2 cents worth in"
    i have been told by a former employer, that once they saw my DAC, they weren't going to consider me, but then someone else in safety read my rebuttal, and i got called in for an interview and to explain my side of the story, and i was subsequently hired!
    Dave_in_AZ Thanks this.
  11. snowwy
    20,591
    13,310
    Jul 6, 2009
    Nope. But his odds are increased. And most locals don't normally call.
    buddyd157 and MachoCyclone Thank this.
