DAC - what's a DAC
Discussion in 'Questions From New Drivers' started by rumbarrel, Feb 19, 2008.
Once you get your CDL, your DAC will be your life. It is the giant permanent record in the sky of everything that you have ever done. In theory, it is your driving and professional record that follows you around and keeps bad drivers from just quickly finding a new job when they have an accident or fail a drug test. But it is also horribly used and abused by unscrupulous companies. They will ding you for every little thing or even put false or only marginally true information on it to prevent you from getting another job.
...and....what do the letters D.A.C. actually stand for?
DAC stands for Drive-A-Check.
Your DAC report is to the truck driver what your credit report is to a consumer. When you are apply for a mortgage the first thing the bank checks is your credit report. If there is something negative on the report, regardless of whether it is true, you will be denied the loan. You DAC report is similar in that when you apply for a job as a truck driver the first thing the prospective trucking company checks is your DAC report. If there are any negative entries you will have a much harder time finding employment.
Your report consists of two parts. The first is your MVR (motor vehicle report) which is your CDL driving record obtained from your home state.
The other part of the report is your work record. This is simply what your former employers have reported. The trucking companies are paid a small fee for your record. This will include notations about any accidents, noted as preventable or nonpreventable, or other problems -
And it doesn't exist in Canada, thank goodness!!!
its the gun to your head that every company can use to blackmail you into doing anything they want if you don't they pull the trigger and can basically destroy your life as a commercial driver they can put about anything they want into it
LeannaMarie hit the nail right on the head.
DAC is part of the USIS. Here's a link. http://www.usis.com/product_details/DAC_Employment_History_File.aspx -
Federal Laws for accuracy of personal credit reports are very strong, at least allowing the consumer the right to dispute incorrect information on a report.
