Damper with or without balancer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Jun 12, 2011.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    So the next thing on my repair list is the damper.... I'm looking in to a couple and wondering if there is a difference if I put a balancer with it...should I go stock, or just go with some performance damper and balancer.....thanks for the input...
  3. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    The Vibratech TVD harmonic damper is better than the OEM's in my opinion. I don't know about Cummins or Detroit build quality. CAT has theirs manufactured in China by a low cost vendor. The liquid silicone used by the vendor that CAT uses isn't as good a quality and will solidify eventually this causes crankshaft failures. VibraTech is the company that also is known by the name Fluidampr and is used by most NASCAR, NHRA race teams for their dampers. The parent company of both of these companies is Horschel Companies located in Springville, NY. Usually the price of the Vibratech damper is lower than the OEM replacement dampers offer by the engine manufacturer
    http://www.vibratechtvd.com/
    http://www.fluidampr.com/
    The crankshaft balancer ring is actually manufactured by a company called Balance Masters. These do work when you install them on a CAT engine. I never seen them installed on a Detroit or Cummins to say that they'll make a difference. I don't think any of the engine manufacturers get the balance on the rotating assembly very close, so you should see an improvement on each of the engine brands. The only bad thing I've found with installing this on a CAT engine is it makes it harder to change the fan belts, especially in a Peterbilt
    I can supply you with both the Vibratech TVD damper and the Balance Master crankshaft balancer, if you're interested PM me.
    SL3406, SHC, RW. and 2 others Thank this.
  4. Diesel Dave
    9,231
    29,461
    Jan 20, 2010
    Hesperia, Ca.
    How can you tell when the crankshaft balancer is worned out and needs replacing ?:biggrin_2558: How does the engine run, rough, etc.....
  5. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    On Cats with the two piece damper there is a line up mark aligning inner and outer rings that will move or you will see the rubber between the two pieces bulging out or missing. When we did overhauls we automatically changed the dampers. The viscous (liquid filled) damper is better you just never know if it is bad, except for an unusual vibration in the engine. It is always good practise to change out at 750K miles.
  6. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    i run a vibratech and a balancer, well worth the money for both.
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Looks like I need to save up a little more $$$ for Mr. Haney's pocket...... turbo, manifold, ecm tune and now this LOL
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Well, the other stuff is nice to have, but a dampner and balancer is a wise investment for the longevity of your engine. And the damper is one of the most overlooked items. You would be surprised the number of times when someone gets an inframe done, they never change the damper. Most engine techs don't even give it a thought. It is the best bang for the buck. I am using a balancer made by Balance Masters I put on when I changed my damper at around 480,000 miles.
    SHC Thanks this.
  9. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    So how much for the balancer and dampner??
  10. rollin coal
    rollin coal Road Train Member
    13,440
    27,392
    Mar 29, 2008
    TN
    $225.00 balancer, $499.95 damper + shipping
    SHC Thanks this.
  11. DumpTrucker
    DumpTrucker Bobtail Member
    30
    Sep 3, 2007
    Joplin MO
    I have the damper and balancer on my n14 and it makes it very hard to change the belts.
