Dash code
Discussion in 'Freightliner Forum' started by Eastward515, Nov 4, 2017.
  1. Eastward515
    Eastward515 Bobtail Member
    hello all
    Can someone help me diagnose what the code sfu 164 sid 254 fail 03?recently I bought a 2010 Freightliner cascadia, I found all rest area lamp and outlet not working. I can see the dash show codes CAB 249 and SFU 164 alternated.All fault code I can see is CAB 249 SID 254 FAIL 03, Another is SFU 164 SID 254 FAIL 03. Any comments are appreciated. Thanks.
  3. tech in need
    tech in need Bobtail Member
    164 254 14
    128 254 14
  4. AModelCat
    161,291
  5. IMSITTINGINYOURCHAIR
    IMSITTINGINYOURCHAIR Bobtail Member
    24
    9
    Sep 14, 2019
    All I could dig up woth a quick google is that the first code means that there is no data recieved to the switch field unit.
    check fuses behind glove box to start with, do a little research about the SFU and see if you can find more on it
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    Apparently the second poster must have had piggybacked onto this old thread with codes of his own.
    I would not know how to reply to this. It will only confuse the situation even though it is not too difficult to google codes in general.
  7. IMSITTINGINYOURCHAIR
    24
    9
    Sep 14, 2019
    well crap, that's what I get for jumping on here and replying after driving all day :happy8:
