Dash indicate light question
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Feb 23, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Thanks for reading. I am trying to figure something out.
    I know the engine light will come on for just about any sensor related issuse.
    My question is on the check engine light. For clairifaction the engine light with the word check in it.
    The code is spn 2659 fmi 0. I'm not asking about the code just the light. While warming up the truck or cooling off after the days drive. And sometimes during the ride the check engine light will shut off. But it comes back on randomly.
    It will show the same code with the check engine light on or off.
    Again i am confused. If its the same code, why does that light come on and off but the code doesn't go away.
    I know what the code is for and will be getting to it this week. I just don't understand the on and off part.
  3. Ridgeline
    22,402
    116,509
    It is coming on and off because the egr flow is off and the ecm sees it so it comes on. The egr isn’t used all the time so it makes sense it would come on and go off.
  4. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    Some fault codes have a severity level 1, 2, 3.
  5. Siinman
    Siinman Road Train Member
    5,291
    13,401
    Mar 5, 2017
    Kansas City, MO.
    I have seen that some of my faults I have had show intermittent or Closed. It might be one that is intermittent. So if you had an issue and it fixed it self for a little bit then it popped back up after you restarted it and caused the same issue.
  6. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Thanks every body they all answered it thank you
    Siinman Thanks this.
