On my 2006 Volvo VNL780 all of the warning lights on the dash flash on and of. To stop it I have to pull over and turn the ignition off then back on. Sometimes that won't even work and I have to disconnect the battery cable and put it back on to clear it.
Dash lights flash off and on
Discussion in 'Volvo Forum' started by Transport Sport, Dec 14, 2016.
What a PITA. Check your connections at your switch. Or maybe your, brain fart, Those square things in your fuse box. Just a guess
first i would try to replace ign switch could also be a dash cluster that is acting up.
It's common for the Dash Cluster to start action up on the 2nd Generation Volvo VNL's.
The only solution is to spend $2000+ at the Stealership for a new one, or look Online and send it out to a Repair Facility to have it Refurbished. -
Mine did this , it was ground wires failing.
I'm considering buying an 07 780 but it has the same issue as transport sport. If it's a ground wire issue I'll take a closer look at it. Thanks.
