dash mpg display
Discussion in 'Freightliner Forum' started by jklopez09, Aug 12, 2014.
  1. jklopez09
    jklopez09 Bobtail Member
    24
    Apr 1, 2013
    Does anyone know how to calibrate mpg that the dash shows? I always check mine on paper at every fill up, but dash is usually over 2 mpg higher. Thanks
  3. Powder Joints
    7,898
    8,203
    Sep 25, 2007
    Rosamond, SoCal
    the dash is using the information in the computer, tire size, gear ratio, eyc... Get your mechanic to correct the information in the computer, it will still be off a little due to tire wear.
  4. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    I don't think you can. Mines fairly accurate within a gallon, I always reset after filling up the tanks. That might help
  5. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    mines 10% off. I always just subtact 10% and its dead on. Excessive APU use (over wee-end) will throw it off to.
  6. jklopez09
    24
    Apr 1, 2013
    So something in the computer is not set right?
  7. jklopez09
    24
    Apr 1, 2013
    Gear ratio and tire size should be right because speedometer is dead on. But the gallons it says I burned is usually low compared to what I put in tanks.
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    not sure about detroit engines, but volvo and MBE may be calibrated. Really dashboard display just reads data saved in engine ECM memory.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    The in dash displays dont now how much fuel is used. Fuel use is hard to figure out. The fuel going in isnt bad, but the return line varies considerably. The computer uses o2 sensors and a series of calculations to guess at the fuel usage. Truth is, the calculations arnt 100% right. Every motor is differnt and the calcs are one size fits all. lmost every truck does not accuratly display mpg. IF you get a scan gaudge, some allow you to out in a % correction to mae it more accurate. My s60 detroit is set at -17% fuel ussage and it is dead on. My cummins is set at +10% fuel ussage and is close. That truck has an apu that the engine computer doesn't take into account.
    icsheeple Thanks this.
  10. Dewey120
    Dewey120 Road Train Member
    1,025
    456
    Mar 17, 2010
    Southern California
    How about one of those scan gauges I hear being sold on the trucker radio? Are they any good and accurate?
  11. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    the KR scan gaudge allows you to calibrate it. you can add or subtract a % from the fuel used so it is pretty accurate. Mine is normaly within a 1/10th of reality.
