Dash readout
Discussion in 'Kenworth Forum' started by KWT, Apr 12, 2013.
  1. KWT
    KWT Bobtail Member
    How do you change the display at the bottom of the tach? Thanks.
  3. Ridgeline
    22,374
    116,079
    I have to ask - what kind of truck?
  4. KWT
    KWT Bobtail Member
    2007 T800. Top line reads hours, bottom has dashes and F degrees.
  5. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    push the reset button 4 times to change from F to C. If all you have is blank lines it sounds like your outside temp sensor is not working, this was a big issue for the 2010 engines as it works the heaters for the DEF. sensor is mounted in drivers side mirror at bottom, can be replace seperately.
