DAT boards, I always wondered how they worked
Discussion in 'Ask An Owner Operator' started by Infosaur, Sep 21, 2009.
  1. Infosaur
    Infosaur Road Train Member
    My company would tell me there's no freight (or there's no freight heading towards my house) but I'd go into the Pilot and check the DAT board and always find a load.
    Since my company pretty much kept me in the dark about the other side of the buisness, how would I go about obtaining a load from a DAT listing?
    Do I just call? Do I have to submit a bid? Do they ask for a lot of information?
    (Obviously I can't just pick up the phone and run for two days and put the cash in my pocket while my company decides they'd rather have me sit for the weekend, but it's not like the thought hasn't occured to me)
  3. phroziac
    phroziac Road Train Member
    3,138
    502
    Jun 16, 2009
    Gary, IN
    are you a company driver or an owner op? When i worked for CRST as a company driver they never had loads going towards my house but they always brokered something up for me so I'd get home. I live in SW michigan so that always meant taking a load to detroit or south bend (IN) and bobtailing it home...they of course never told me where the load came from, but it was obvious it was brokered because of the way it happened.
    Annnd...if you're an owner-operator, most companies have a pretty specific procedure for doing exactly this. Just call them and ask. :) They'll of course want their cut of the pay but it should be fine.
  4. Allow Me.
    10,676
    12,237
    May 28, 2009
    Rancho Mirage, Ca.
    Forget about it if you are a company driver. As an O/O or L/P, you need to "qualify" to get that load. You need to prove your authority/insurance/reliability etc. There are as many flake brokers as trucking companies. Just because it's posted on a truck stop load board doesn't mean it's a good deal. If the load/broker has a bad reputation, your company won't deal with them. :evil3:
  5. JasonTheRock
    JasonTheRock Light Load Member
    257
    102
    Feb 7, 2009
    Oakland, Ca.
    If your carrier uses brokers, your carrier will need to sign up with that broker if they already haven't. I would pull the load information of the board and give your carrier all the info, they can call and get the rate, etc. Signing up with a brokers is no big deal, basically a few faxes back and forth, and the carrier insurance company sends an ins. certificate. The ins. certificate states amounts of insurance the carrier has, possession of the certificate also means the broker is kept up to date of any changes to the carriers policy.
    If your carrier allows you to use brokers I would be all over those load boards! Doesn't matter if your a company driver or owner operator, if your carrier will use that broker on the board they can assign you the load, you would likely be paid whatever you get as a company driver or O/O.
  6. Allow Me.
    10,676
    12,237
    May 28, 2009
    Rancho Mirage, Ca.
    Dispatchers don't only dispatch, they constantly look over the load boards to find freight. If it's a large company, the "load planners" are doing this.
