Anybody convert their current davco 382 to either a electric heat or coolant heat to keep the fuel warm? Your thoughts?
Davco 382 coolant/electric heat
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by istumped, Jan 12, 2022.
The coolant way is the only way. The electric doesn't produce enough heat to make a difference.
Would you also add artic fuel heater to tanks as well? I've been told those are coolant heated as well? Don't know for sure.?
Use them twenty years ago but fuel has gotten much better now and find no need. The thing we do is use 25 micron fuel filters haven't had problems in years running upper Midwest. Just coolant heated davco, power service and 25 micron fuel filters. We don't shut trucks off any time it below zero temps.
Hammer166, BoxCarKidd and ibcalm19 Thank this. -
Copy that. Thanks
You can buy a couple years of fuel treatment for the price of a set of injectors. It takes maybe a few minutes per month to buy the fuel treatment and add it with every fuel-up for the 4 months it is necessary. -
I'm gonna assume you tie into the coolant lines that go to the air compressor? -
