Davco water separator filter, which one for the D12
Discussion in 'Volvo Forum' started by TheEnglishMan, Nov 16, 2013.
  1. TheEnglishMan
    TheEnglishMan Light Load Member
    231
    60
    Oct 3, 2012
    Davco says to use a 25 micron one ( fleetguard fs19765 ) but recently a volvo dealership told me to go to a 50 micron one ( fleetguard fs19729 ). Can someone with real knowledge tell me which one I should use. Thanks.
  3. TheEnglishMan
    231
    60
    Oct 3, 2012
    Got that and know that but as I said, volvo told me to use the 50 micron not the 25 micron.
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    You would need a secondary filter after the davco to filter down to the 25M. Maybe you have 2 fuel filters?
  5. TheEnglishMan
    231
    60
    Oct 3, 2012
    Actually I have three filters. The davco, then the volvo water separator filter ( which I am told is 25 microns) then the volvo long life filter which I am told is a 7 micron filter. But davco state to use the 19765 filter in there unit, which is 25m.
  6. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Ok, so it make sense now. You have a water separator first, then the davco, then your volvo filter @7m. SO the davco should be "larger" in microns, because you are doing the final filtering in the volvo filter. It will 1) be easier to suck through the larger micron filter, 2) extend filter life by just stopping the larger particles (50 micron and over). The water separator will stop the 25- 49 micron particles. The "smaller" volvo filter will 1) stop the smaller "7M" particles, 2) last longer because it is only stopping the 24-7 micron particles that the water separator filter let by. I hope that makes sense to you.
  7. TheEnglishMan
    231
    60
    Oct 3, 2012
    No, the filter flow is as follows.
    1st. The davco, currently with a 50 micron filter as per advice from volvo dealership. Davco however call for a 25 micron filter, as per the chart you posted a link to.
    2nd. Volvo water separator filter. Told by dealership that that is a 25 micron filter.
    3rd and final, 7 micron long life volvo fuel filter.
    i got the logic, but should I have a 50 micron or a 25micron as the 1st filter?
  8. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    the 25 micron davco would be redundant with the water separator after it. the way you have it setup now steps down the filtration. as you have it listed in your last sentence sounds logical
  9. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Someone must have put the davco in with that in u dont need the volvo water separator or vise versa ive personally never seen a d12 engine woth both on they sefeat the purpose of each other
  10. TheEnglishMan
    231
    60
    Oct 3, 2012
    Well not really. IMO you can never over filtrate. The cleaner fuel getting into the cylinder the better. Hence the FASS fuel polishing system. The water separator as a term is a bit misleading. It's just a larger micron rated filter, as water particles are larger, but obviously it will stop other particles. Having a progressively smaller micron filtration series of filters works by protecting the next filter in the series from clogging. 50 protects the 25 and the 25 protects the 7. Thus extending each filters service life. I was running 25,25 then 7. The Davco is much easier to change and has a higher capacity than the Volvo 25. I have run that configuration for a year with no problems. Volvo in New Haven IN told me to go 50, 25 then 7. Perhaps I'm the only one with this setup. So I will just watch my mpg, performance and time before the filters get clogged and determine which setup is best.
