DD 15 engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shmelk, Sep 6, 2022.
  1. shmelk
    shmelk Bobtail Member
    15
    12
    Sep 1, 2022
    Hi,
    I've heard differing views on the dd15. Until 2017 I understood they break down very often because they couldn't figure out the emmisions problem.
    So let's say I get a model after '17 is that a good choice.
    Need to get a new engine for my cascadia 2011. It had a dd15 14L until now.
    Please post and share what you advise.
    Thank you so much.
  3. Espressolane
    18,358
    114,500
    Why a new or different engine?
    If the block is good, an overhaul would be most economical.
  4. shmelk
    15
    12
    Sep 1, 2022
    Engine overheats.
    Mechanic told me not worth it to fix.
  5. Espressolane
    18,358
    114,500
    Get a second opinion. Over heat situations could be a few things.
    AModelCat, Judge and Crude Truckin' Thank this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,054
    5,475
    Mar 18, 2021
    St Malo mb
    Engines aren’t the problem so buying a 17 only means you need to buy all the emissions for a 17 .. first thing I’d check on your 11 is water pump they are cheap and wear out .
