DD15 and DD16
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NFDDJS, Oct 3, 2012.
  1. NFDDJS
    NFDDJS Light Load Member
    267
    37
    Jul 8, 2012
    New Hampshire
    So I have been looking at a Western Star with the Detroit.
    I was told you could get 600HP and 2050TQ from the DD15 in the past but now that the DD16 is out now you can.
    Any way to get the old programming?
    Also any of you have a DD16?
    I am trying to decide if getting the DD16 is worth the $8200.00 over the DD15.
    How do you all like the DD15-16?
    I would really like to hear more about these motors...
  3. imbzcul8r
    imbzcul8r Bobtail Member
    5
    Mar 21, 2010
    bc, canada
    I have a DD15 1850 in a 2012 Western Star
    The extra cost of the DD16 and the warranty made me decide to go with the DD15.
    At first I was really kicking my ### I didn't buy the DD16, the DD15 felt pretty gutless compared to my 3 other trucks with Cat power.
    After a year however it seems to have come to life. We pull lowbeds so it is rare that we are pulling identical loads
    but we did have a run this summer where we were pulling 7 axle lowbeds with 980H loaders over the same route at the same time, my other truck
    a Western star with a stock C16 600/2050, the DD15 pulled neck & neck with the Cat & ended up about 15% less fuel on the trip.
    More recently we were running similar loads at the same time, my other truck a 07 Western Star 550 acert/1850, we did a lot of off highway pulling and the DD15
    did about 10% better on fuel. The jake is GREAT, holds a lot better than the cats and cab noise is a lot quieter also.
    I have never seen it do a regen, maybe because we are working the bag off of it most times? It does seem to use a fair amount of DEF but it's my first truck using
    cow piss so I don't have anything to compare with. Overall after a year I am satisfied with it. Ask me again in another year.
    NFDDJS Thanks this.
  4. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    As of January 2013 it will be detected. That is for Cummins and Detroit both since the Detroit uses the Cummins turbo and exhaust system. They joined together to create a parameter check program that will scan all users registered on DCSN and Insite. If anyone hooked up and is not registered and (here is the big one) if the ECM program shows any version placed that is not done by a dealer or certified shop, your warranty is out the window. I just did a training class for Van Hool (who is introducing a truck next year) and was trained with the new software for both companies. Too many claims to later learn ECM changes were made. They are cracking down and doing it hard. So beware of any future ECM changes.
    It shocked me to learn that info. Now you have to verify these shops hooking up have a active license for the software and not a bootleg. Then if ECM changes, they better be an approved shop or you just lost their warranty.
    Oh, all registrants will be mailed a certificate in December to post and make visible to the customer so they can verify the registration with expiration dates.
    The companies are changing the way us shops will be doing business.
  5. Shaggy76
    831
    307
    Feb 22, 2012
    Orlando, FL
    Oh, how the software worked, when you hook up it does a full system scan on the truck. It then sends that information to the network and after the check, the tech can move on. It takes about 3 min to do. If there is a change, you get a warning that the ECM has been "footprinted" and a code goes into the ecm. It then loads to the manufacturer and pulls your node id. (that is the esc you are using to connect) It then pulls up all the stamps of who connected and shows what they changed in a special file that gets sent. Then a notice comes up that says "warranty voided" in big letters. The customer who owns the vehicle will then receive a print out of who, what, how, and why of warranty void with a number to call. The customer then has to call the number. The tech can then only pull codes and can't clear them, and truck is in derate mode until owner calls the number and gets a code put in the network to remove the derate.
    The high question we asked was how can they derate if vehicle is owned by someone else. Response, they own the proprietary information and the warranty. Therefore, they can derate the same as DEF, CES, DPF, engine protect, etc. Difference is they are derating for mandatory customer notification to protect their proprietary information. I can see the lawsuits already...
  6. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    There will be a way round it everyone thought the cat sdp could not be cracked and look what happend.
    Its just time and money something that the big tuning shops have. In some ways they are miles ahead of the manufacturers with online tuning ect.
  7. Cat sdp
    Cat sdp . .
    20,858
    72,033
    Apr 8, 2012
    Orion's Belt
    Shaggy , what happens if the warrantee is expired and they see that you have tuned their crappy software ? Does the manufacturer call my mommy ?
    MNdriver Thanks this.
  8. veinst75
    veinst75 Bobtail Member
    Dd16 with delete by blackbox install by dealer..over year now spent 25000$ in visits to dealer complaints about no power and couple injector replaced then low pressure pump then high pressure pump..still no power and dyno results 411hp to wheels ..im like y and how but find out ecm was swapped at blackbox install and has dd15 programming so where do we go from here and what damage occured..we haul 88000 kgs so where do we go get the correct set up?
  9. runningman0661
    5,151
    14,839
    Mar 5, 2009
    Clover, South Carolina
    You choose a delete, you roll the dice. Hope it was worth it.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    DD15 was available with up to 560 hp 1850 torque. I had one. Only DD16 goes to 600/2050, I have 600/1850
