hi everyone please share your experiences and knowledge about my problem.
a month ago i had regen every 300 miles, took it to a shop cleaned the filters for $550, connected to computer,performed regen and lights on dash didnt go away ( check engine, stop engine and flashing dpf) tried to regen at least 5 times, no change. ... ash soot level was high according to computer. thought it might be the sensor and replaced with a new one. no change again. took it to another mechanic nothing found. took it to another mechanic and performed regen, boom!!! lights are gone now. took a load drove 800 miles then again... short story long i still have the same problem and what can u guys recommend? im thinking its the doser injector.. can it be? thanks in advance
dd15 dpf regen problem
Discussion in 'Ask An Owner Operator' started by mcdsobe, Oct 15, 2016.
Page 1 of 3
What is the fault code you are getting?
Dozer injector is cheap to replace, I used to replace mine every 150,000 miles -
There are too many lose ends to give you advise on the engine check lights.
We would need the following
Year, make and model engine. Engine hours, not mileage. What brand of DEF and how often you preform a full PM.
You must also realize that certain parts must be replaced according to manufacturing specs. So you need to read the owners manual section on DPF filters and standard maintenance schedules. Doing a regeneration only works to temporarily clean a dirty DP filter. At some point the whole filter will have to be replaced as well as other components like electronic sensors and thermocouples, tubes and connectors.
It could cost up to 2500 dollars to do a complete upgrade on an older system at a dealer. -
Worth pulling the system yourself and getting a full bake. Dealerships often don't have great ovens, it pays off to find a local contractor with a great pulse oven. When I worked for Penske we used an outside contractor to bake dpf's, international and freightliner often gave us back dpfs that only flowed at 40-60%, we would end up sending them back out for re-cleaning.
Brand new dpf on a 09 t660 was $4500 alone.
Page 1 of 3
