DD15 engine eating one gallon of oil for every 5000-6000 mile, Please advise.. :(
Discussion in 'Freightliner Forum' started by asianofthecorrs, Mar 24, 2013.
Page 5 of 7
How can I clean that box ? It's only burn oil on low rpm. Between oil changes less than half gallon. 15000 miles.
Is that 15,000 mile oil changes?
Yes.
That is the recommended drain on a pre-egr Series 60 engine. Not sure why one would change that soon with a DD15. I could see 25,000 to 35,000. Detroit recommends 50,000, but that goes outside my comfort level. I haven't changed a truck engine oil at less than 20,000 miles in over 2 decades. Never lost an engine and took a couple over 1 million with no major repairs. One to 1.4 million and it went right to work for next owner.
What are you basing the 15K mile OCI's on? -
Or 10w30
I must not be wrong. Read the 2016 Detroit Lube, filters, and Fuel manual. Also check new delivery spec sheets for the last few years for DD13 and DD15, factory fill is 10w30.
Tolerances mean nothing on what we are discussing here. Viscosity is NOT thickness, it is resistance to flow. Ask Isaac Newton in the next life and he will enlighten you. And a 5w30 has the same viscosity at 100c (engine operating temp) as a 10w30. Roughly 12.5 cST. Only the cold flow is different, and not by much. This tighter tolerances nonsense as it relates to oils is passed around the internet as if it were fact.
A 0w30, 5w30, 10w30, 15w30, and a straight 30 all have the same viscosity at operating temperature. The number before the "w" has little to do with the viscosity classification of the oil, it is a cold flow rating. The "w" stands for winter, not weight. A 0w30 gets it's CCS rating at -35C/-31F, a 5w30 gets it's CCS rating at -30C/-22F, and a 10w30 gets it's CCS rating at -25C/-13F. And to prove the point, say for a 0w30, there is no such thing as a 0 weight oil. Then why is it a 0w30? Because the oil is able to meet the lubricating oil cold crank simulator (CCS) standard at -35C to qualify.
So many myths, so little time.Last edited: Nov 28, 2016
mhyn Thanks this. -
Page 5 of 7
