DD15 engine replaced with D60
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1dan, May 2, 2018.
  1. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    My dd15 engine was eating about 5 gallons of oil per oil change and i decided to do an overhaul. Unlucky 50.000 miles after the engine seized due to main bearings getting stuck. Shop wont pay for the repairs and i dont want to put up with another DD15 since they are so bad. ( the cause they suspect is bad crankshaft, very common problem)
    What i want to do is to install a factory reman D60 instead.
    Has anyone done that, is it worth, how much did it cost and who does it?
  3. Peterbiltt
    Peterbiltt Light Load Member
    233
    85
    Aug 21, 2014
    Ontario Canada
  4. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Do a google for dd15 problems.
    I'm not sure a d60 would work. With all the computer sensors and emissions components and what not.
    You might be buying a can of worms that could cost more then what you've got.
    Since the engine already quit at only 50k miles. I'd say mechanic error. Not micing the crank and installing the right sized bearings.
    The crankshaft story might be just that. A BS excuse to get out of warranty work.
    Bean Jr. Thanks this.
  5. Peterbiltt
    233
    85
    Aug 21, 2014
    Ontario Canada
    I think the problems from the oil pan where the pick up is. Theres some plastic type block there. My mechanic has 2 opened up because of that, right out of warrenty.
  6. DUNE-T
    DUNE-T Road Train Member
    6,901
    16,677
    May 10, 2015
    Detroit, MI
    If they sell Cascadia gliders, they should have harnesses and other stuff needed to install a pre emission Detroit, however it won't be legal from the EPA standpoint and if you get caught, you might face some serious fines. "If caught"
    snowwy Thanks this.
  7. snowwy
    20,527
    13,262
    Jul 6, 2009
    Forgot to mention another thing with the crank story.
    If your bearings spun around. I"m guessing your engine was knocking. Means the crank was slapping the piston rods. Not good for either crank or rods and both will have to be either machined to be round again. Or replaced.
  8. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Kustomtruck in Oregon makes a kit that contains everything that you need (wire harness, tubes, hoses etc.) cost around $7500. Just find a good donor engine......
  9. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    The engine was not knocking but they tried to fix the crank but they said its too bad and since the engine overheated no one recommends to do a rebuild again. But the worst part i heard about the crankshaft story from the dealer and other shops. They were blaming the bad oil that was not lubricating enough. ( 15w40 mobil 1300 at Speedco )
  10. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    Thanks, i found factory reman engine and harnesses from people that do glider kits for 40k, i just need to install it somewhere else cause they dont do it. Only issue is from legal stand point who checks that stuff and what can they do about it? Did anyone have any problems with EPA?
  11. 1dan
    1dan Bobtail Member
    12
    4
    May 2, 2018
    2010 cascadia
