DD15 from Cat C15
Discussion in 'Experienced Truckers' Advice' started by Fraser389, Mar 1, 2018.
  1. Fraser389
    Fraser389 Bobtail Member
    4
    Hey guys and gals, new to the forum here!
    I have quick question about going from a cat c15 550hp to a DD15 560hp. I run mostly in the hills and run loads around 108,000 pounds. Wondering if someone with experience driving a dd15 could give me a little insight on how they like to run and particularly shift. Never have to push the kitty over 15 or 1600 rpm and I'm wondering if I can expect the same from the detroit in the same rpm range the c15 likes?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    DD15 560 HP does not exist. You may see on label 560HP value but if you connect the diagnostic software you will see it is 505 HP or lower..
  4. ThomasTrueTrucker
    ThomasTrueTrucker Bobtail Member
    18
    18
    Mar 2, 2018
    And the worst part of it is you'll have to post a picture of the new truck you're driving, because I don't think that red Pete has a DD15 engine in it!!!
  5. Fraser389
    4
    Big NOPE on the detroit/pete lol But after looking into it the dd15's only pushing 505hp....should be a big let down... hopefully short lived
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    They do have pretty good bottom end torque, not sure how that translates to pulling the heavier loads, but they do pull down pretty well to 1000 rpms.
  7. Fraser389
    4
    Thanks for the input all! Haven't had any personal experience with the detroits, mostly cat and a few cummins
  8. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    I've never driven anything with a cat, but I drive a Cummins. The dd15 in the freightliners did pretty well going up hills, but the Jakes suck. They don't hold until you get above 2000/2100 rpms, and even then the Cummins can run down hills faster without needing service brakes at the same weight. So it's a tossup.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    The isx 12 I drove in the oilfields (425/1650) seemed like they would walk all over the 455hp dd15 I'm in now. The jakes on the 09 I'm in suck. The newer dd has better jake especially paired with dt 12 trans
  10. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    Depends on the motor setup.
    The 16 FL i drove with DD15 had the best jakes I've ever had. the 13 FL was pretty close.
    The 06 C15 i drive now. Don't have much torque and power. And the power range is 1500 to 1800. I can't climb the hills with anything lower.
    I think it's only rated for 400 hp. I pull close to 100k and i get my doors blown off by doubles all the time. They pull max weight of 129k.
    Oxbow Thanks this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,296
    Apr 9, 2009
    Humboldt, Sk
    Get one with a DD16, mine has 600 hp at 1,850 torque. You can also get it with 2,050 torque. But the dealer said tires wear down faster due to the excess torque.
