DD15 Fuel Filters
Discussion in 'Freightliner Forum' started by Shadetree Trkr, Sep 8, 2015.
  1. Shadetree Trkr
    Shadetree Trkr Bobtail Member
    15
    5
    Sep 7, 2012
    Wondered if anyone has ever changed the fuel filters on the DD15 themselves. I've changed the fuel filter on the frame under the cover. Had an issue with a T/A improperly replacing the water separator filter when I first got the truck. Since then, I only change them at the dealership. Speedco gave me the filters when I had the service done last. So I was thinking of giving it a go. Can't get mad at myself if I mess it up.:D
  3. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    Not as easy as a spin on but still quick. Just take care not to get a kink in the o-rings.
    Edit: You'll need a 36mm socket and torque wrench.
    Shadetree Trkr Thanks this.
  4. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    If it's a davco, super simple, but there is a proper procedure and special tool needed.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    I have changed both. the davco 482 and three filters on engine.
  6. mhyn
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    use lubrication on o-rings. it is provided in filter kit box. use hand pump about 2-3 minute until you feel its hard to pump.
  7. Shadetree Trkr
    15
    5
    Sep 7, 2012
    A kink in the O-ring was the problem the "mechanics" at T/A caused. Couldn't get the truck to start due to air in the fuel system. Dealership discovered the problem 3 days later. Cluster f--- all the way around. Thanks for the info.
    icsheeple Thanks this.
  8. Star4900
    Star4900 Medium Load Member
    607
    521
    Mar 16, 2015
    Northern Ontario
    DO NOT CHANGE THEM AND THE OIL FILTER AT THE SAME TIME also. There was a service bulletin about this after dealerships blew up a few Detroit and Mercedes due to having to crank them over so long to pick up fuel with no oil pressure.
    My DD15 has to run quite a while at road RPM before it will start normally again after the fuel filter.
    So do them one at a time running the truck in between.
  9. icsheeple
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    On my davco and bypass filter. It's always important to not twist the bowls. I learned the hard way. Lost 6 gallons on the highway after a bypass oil filter changed when I kinked the gasket. Another time I was getting bubbles on my davco from twisting the see through bubble, bowl thing instead of the threaded collar. Doh!
  10. Dave_in_AZ
    374,793
    Which T/A was that?
