The truck spinning over turns 90 rpm’s nothing more. It has the three filter system on it and sitting here has no fuel in filter base. I prime truck up with primer pump and just flows back into the tanks not priming the motor. Battery voltage is up at 12.5 and drops at the starter to 7.8 while cranking. Trucks whipping my butt. Help
DD15 loosing fuel prime
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mechanic jeff, Feb 22, 2024.
Here's a thread on your issue, its Volvo, and from 2013, but fuel is fuel.
Sounds like check valve is stuck open.
Dump this into Search bar on top right of page.
Hard starting and Davco 382 leak down issueConcorde Thanks this. -
Battery voltage dropping to 7.8 while cranking sounds like a problem all it's own.
