DD15 problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tsvetan Tsvetkov, Jul 8, 2016.
  1. Tsvetan Tsvetkov
    Tsvetan Tsvetkov Bobtail Member
    9
    HeY Guys.I got issue with my 2011 dd15 Cascadia with 577k miles on. Somethimes when i am driving it looses power for 6-7 seconds and then the power comes back and this goes for like an hour.Is that a regen problem or something else? Thanks a lot
  3. mcdsobe
    mcdsobe Light Load Member
    80
    35
    Feb 23, 2015
    That sometimes happens to me as well but not for 6-7 secs maybe 1 or less. When did u do pm? Change your oil&fuel filters with good quality ones. Change your air filter. That sometmes works for me... if not have your dpf checked, still have problem? Check your injectors. Also there might be a short somewhere. Im not a mechanic or such but these are the only things i can think of. Good luck!
    Tsvetan Tsvetkov Thanks this.
  4. Tsvetan Tsvetkov
    9
    It actually drop off power when i go to 65mph and then whenever the speed goes under 65 i got my power back.It just does not have any throttle responce when it gets to 65.No codes dough!
  5. mcdsobe
    80
    35
    Feb 23, 2015
    Is ur truck governed?
  6. Tsvetan Tsvetkov
    9
  7. Tsvetan Tsvetkov
    9
    No cruise control either or jail break;(
  8. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Jail Break is what you do with an iPhone.
    redoctober83 Thanks this.
  9. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    Classic clutch switch symptoms. I bet that's what is causing your loss of power as well, progressive shifting is cutting RPMs.
  10. Dave_in_AZ
    415,902
    Yea there's a micro switch that closes when your clutch pedal is out. It's a safety that cuts the cruise / jake when you depress the clutch in case you don't turn them off before you depress the pedal.
    It could be clutch pedal return spring as well, if that spring broke, the clutch pedal doesn't come up quite all the way and won't close that micro switch.
    Pop the cover off by you clutch pedal, you'll see the switch.
  11. pete1
    pete1 Heavy Load Member
    Throttle module? Or the harness leading to it? Maybe? Those things are all harnesses and modules and if you pressure wash the engine ther can be a lot of corrosion.
