DD15 tuner question
Discussion in 'Ask An Owner Operator' started by Highrisk21, Aug 25, 2016.
  1. Highrisk21
    Highrisk21 Light Load Member
    132
    63
    Aug 22, 2016
    Anybody have any experience with running some kind of tuner on a dd15? I have a 09 cascadia and was looking around for a tuner like a bully dog or something but there's so many I dint know who's good bad or if any of them are really worth the money. I'm looking to get a little more power without going crazy with turbos and manifolds. Any info or direction will be great. Thanks
  3. Boardhauler
    Boardhauler Road Train Member
    1,712
    3,485
    Dec 21, 2008
    Ballin' in it for Shakey
    Google steinbauer. I have no idea idea if they are any good.
    Somewhere I recall hearing that Pittsburgh Power has or is working on a tuner, you might call them.
    I'm trying to argue with my Freightliner dealer that mine could be set to 505/1750. I'm not having much luck, a Detroit dealer is probably my next stop.
  4. Highrisk21
    132
    63
    Aug 22, 2016
    I've read somewhere about these motors being turned up to 550 and 1850 or something to that nature. I'll keep looking. Thanks
  5. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    I have 700hp on a cleaned up DD15....
  6. SLCTrucker
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    I had mine originally turned up by Detroit, 565/1800 & those are factory settings
  7. Boardhauler
    1,712
    3,485
    Dec 21, 2008
    What was it set at originally and which dealer turned it up? Was it under warranty when you did it?
    Thanks for the help!
  8. Highrisk21
    132
    63
    Aug 22, 2016
    I had my independent mechanic check mine out and he said it was turned up all the way.
  9. Highrisk21
    132
    63
    Aug 22, 2016
    Looks like mine might be put on hold because of an oil leak that today I found out needs to go to Freightliner or Detroit because it some gasket or seal that on the back where the block connects to the transmission housing. I called Detroit and they quoted me $1,500-$2,500 just in labor. Kinda pissed right now mainly because I just put about $6,000 into the truck with in the last 2 months.
    Did all drums,shoes, slack adjusters,all shocks including cab,clutch switch, firewall pass through air hose manifold,air compressor,power steering pump, and rear air bags. all was maintainece that I needed except the air compressor and while I was there I put the new power steering pump on because it was no more labor so might as well do it. Oh well that's trucking. That's why I tell my drivers to save there money for times like this with high Shop bills and days off work.
  10. 77fib77
    77fib77 Road Train Member
    10,390
    64,869
    Jul 7, 2010
    St Louis
    How bad is the leak?
  11. Highrisk21
    132
    63
    Aug 22, 2016
    I'd say prob 4-6 drops after being parked for a few hours
