DD15 wont fire after fuel filters changed.
Discussion in 'Ask An Owner Operator' started by MTMAUS, Aug 4, 2023.
  1. Opendeckin
    Opendeckin Medium Load Member
    455
    1,272
    May 20, 2018
    Usually when mines being stubborn to prime ill keep it running on ether until the fuel pump turns enough to prime the system. Usually 10-15 seconds. If you spray just enough to keep it running it shouldn't damage anything.
  3. MTMAUS
    MTMAUS Light Load Member
    223
    175
    Sep 28, 2019
    Thanks, do you spray the ether before or after the air filter? Or do u just take the air filter out?
    My mechanic said only option left is to use spray until it goes.
    Is Ether or Brake ckeaner better? Does it matter?
    Am nervous about stuffing it...
    Thanks for the help.
  4. Opendeckin
    455
    1,272
    May 20, 2018
    I pop the boot right before the turbo and spray it in there. Wd 40 or the like is safer, but you need 2 people to turn the key and spray simultaneously whereas with ether you can spray and then go turn the key
    77fib77 Thanks this.
  5. 062
    062 Road Train Member
    6,233
    33,549
    Oct 20, 2013
    Fill the separator and leave the cap off, then pump the primer. If the level doesn’t drop your primer is bad or you have a restriction.
    If it does drop, then pump it down and refill two or three times before trying to start.
    77fib77 and LameMule Thank this.
  6. kwswan
    kwswan Road Train Member
    1,960
    10,452
    Jul 26, 2009
    mcminnville,tn.
    Get you some good starting fluid instead of brake cleaner. If you have a John deere dealer close by get some of theirs.
    lester and Constant Learner Thank this.
  7. Rideandrepair
    17,357
    56,315
    Aug 8, 2015
  8. wichris
    wichris Road Train Member
    4,348
    8,753
    Jan 17, 2011
    One of the plastic caps is cracked/not sealing or O-ring on filter is missing.
    Last Call Thanks this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,035
    5,432
    Mar 18, 2021
    St Malo mb
    I had to change a filter on the road due to algae. Our mechanic told me to apply a small amount of air through the fuel tank vent hose. I pumped primer maybe 50 times then tried it the dd15 fired right up . After I slowly opened tank cap to release pressure.
    LameMule Thanks this.
  10. MTMAUS
    223
    175
    Sep 28, 2019
    Something doesnt seem right, when I start it with starting fluid spray it starts, fires, then konks out, even if i keep spraying the starter fluid.
    It should run longer than 2 secs when spraying starter fluid yeah?
  11. MTMAUS
    223
    175
    Sep 28, 2019
    FML, so this truck wont go and to add insult to injury the truck I had hooked up to it to keep the batteries charged will now not do a burn... so thats 2 trucks heading to the shop....
