My truck is loosing alot of coolant out my exhaust and its leaking at the clamp where it turns up to stack and it uses between 1-5 gallons of coolant a day but no overheating and occasionally it blows a Lot of coolant out the overflow in pulses while I'm sitting and also air compressor went real weak at the same time.do you think the air compressor is causing all of this or did it just happen I blow a head gasket and air compressor at same time?oil is not milky
DD60 14L problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ridgerunner77, Oct 22, 2017.
