Ddec 4 cam swap experience
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by catwrench55, Jul 24, 2017.
  1. catwrench55
    catwrench55 Light Load Member
    211
    88
    Jan 5, 2015
    Hey.
    I've got a early ddec 4 that is set from original 430/470 to a compatible factory 500 tune. I have had 5915 injectors and 171702 turbo for a while and truck ran pretty darn good just always want more.
    Had a 4912 cam swapped in while I took family on vacation last week. We had to ream the threads from the cam gear hub to fit the 20mm bolt as per Erich for SS60 recommended. Also added Jake's while I was at it.
    Truck idles like a sewing machine but once I picked up a load I wasn't that impressed, noticeably less lugging/ recovery @1400 rpms. May only pull slightly better over 1800 Rpms than before and just doest quite feel right.
    I'm wondering if they retarded the cam gear a tooth while reaming out the hub, anyone have thoughts.
    Only other thought is if ecm program needs to match cam as i didnt change it yet.
    Thanks for any thoughts, Bo
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Not sure about the rest of it , but your tune don't care what cam you have.
    I would double check if cam timing is correct
    wore out Thanks this.
  4. Diesel Dave
    8,588
    23,993
    Jan 20, 2010
    Hesperia, Ca.
    You need to reprogram ECM.
  5. catwrench55
    211
    88
    Jan 5, 2015
    Erich thought a ecm program was needed also.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Sure add fuel to anything and you'll get more power.. Now you don't know if it's the cam or the fuel but gee it sure pulls.
    One other thing I thought after I posted.
    Did your mechanic use the injector hight spec for the old cam.??
    The 4912 cam will probley need a different timing pin to set your injector hight. Just food for thought.
  7. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Did you check cam timing via the injector lobe lift method?
  8. allan5oh
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Is the 8309 cam I have good? What would be a better replacement without needing to raise rpm?
  9. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    8309 cam is one of the best ones there is.. came stock in my 2000 year ddec4 14L
  10. catwrench55
    211
    88
    Jan 5, 2015
    Injectors were set with 81mm tool for this cam, mechanic assured that it did not jump time but no lobe timing procedure was done.
    I'll be in this Louisiana oil patch for a few weeks recouping some money to decide what to try next.
    Appreciate all the input.
  11. Diesel Dave
    8,588
    23,993
    Jan 20, 2010
    Hesperia, Ca.
    Doesn't the bullgear have something to do with the timing ? I know very little about jimmies, drove the mechanicals ones in the late 70's, anyways.... I read few members on here that always are talking about the bullgear. Just saying.
