ddec iv ecm not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Aug 29, 2014.
  1. truckerbangin
    truckerbangin Light Load Member
    262
    44
    Jan 22, 2013
    running a detroit diesel series 60 ddec iv and its the second time a ecu has died on me. same scenario on two different occasions trucks came to yard running fine next morning trucks roll over but wont start. has any one had issues with ecm's going dead over night?
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Struck by lightning during the night.
  4. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    Someone exchanged it during the night.
  5. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    I have a Cummin's, but mine went bad while I was starting truck. Motor started but cel and sel came on so I shut motor off. Read codes. Tried to start and motor would crank but not start. I was jump starting. I was told the ECM had a power surge while starting.
    Is your ECM bad or did you just lose power to it.
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    ECM. has a small batt. built into it, if it goes bad truck will not run, 1st be sure truck is powering the ecm with key on?
  7. truckerbangin
    262
    44
    Jan 22, 2013
    thats the first thing i did when i took ecm off
  8. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Same happened to me. There is a fuse right at your batteries that runs to ecm. Check the fuse and make sure it's clean..... there's a few of em so check em all.
  9. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    Orange & green wires are the ground, on the right ecm connector might went bad
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what kind of internal damege? Remove back cover and inspect
