Dealer can't fix the Oil leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by avmander, Oct 27, 2017.
  1. avmander
    avmander Bobtail Member
    10
    took the 2012 Freightliner Cascadia to Dealer 2 times for Oil leak.
    First time, they told me its somewhere near compressor is so they had me replace compressor at that time as well so ended up paying 3k for it.
    and the oil was still leaking so went back to the dealer second time and they said its the rear main seal is leaking so i ended up putting a new clutch the rear main and paid 4k for that.
    and the oil leak is still there what should i do now please advice.
  3. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Don't go back to that dealer. Really. The compressor is at the front of the engine and the rear main seal obviously at the rear. The leak must be jumping around.
    buddyd157 and baha Thank this.
  4. Tug Toy
    Tug Toy Road Train Member
    6,935
    72,514
    Jul 4, 2015
    Corn field
    What engine?
    Oxbow Thanks this.
  5. avmander
    10
    Its a detroit dd15
  6. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    you need to get a good flash light and inspect oil leak area at night...
    avmander Thanks this.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Wash it all then put a dye in the oil and you follow it with a black light. Can get it at Napa
    avmander, baha, ChaoSS and 6 others Thank this.
  8. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    You could have saved $7K by going to Blue Beacon, get an engine wash, then follow up with some brake cleaner, clean real good...and then locate the leak.
    Oh, wait, you can still do it... and this time, you will know for sure where the leak is coming from.
  9. Rrts247
    Rrts247 Light Load Member
    75
    45
    Feb 12, 2017
    I had same problem, it was the head gasket, oil leaking around the ledge and dropping here and there, clean head gasket area real well. You will find it.
  10. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,409
    Aug 28, 2009
    Airlie Beach QLd
    Sounds like whom ever they employ as their mechanics isn't very good at fixing leaks it'd kind of be pretty obvious where the oil was coming from yet they've tried not once but 2 twice to fix this up at a cost of over $7000 looks like a real scam to me. although i guess you can still claim your expenses on your tax return.
  11. buddyd157
    buddyd157 Road Train Member
    13,513
    34,629
    May 25, 2017
    under a shade tree
    on a frightshaker i once had (company truck) the oil was leaking from a crack in the oil pan. it was a "plastic" oil pan as i recall.
    get the engine as clean as possible. yes, you can add a dye in the oil. yes you can use a blacklight to find it, AFTER a few miles or so to get that oil fully circulating and hot, to drip out of any area where there is the problem.
    or you can simply wash the engine, top off the oil, set up a sheet of paper under the entire engine bay, run the engine till operating temps, then shut it down.
    depending on the rate of the leak/drip, it can take some time, so do this when you are maybe on your reset?
