Deciding on a radio
Discussion in 'CB Radio Forum' started by Samuelh, Sep 4, 2018.
  1. Samuelh
    Samuelh Bobtail Member
    36
    39
    Jun 23, 2018
    So i have a cobra 29ltd that i had peaked and tuned. Is that radio worth adding ssb, talk back etc etc, you know all the toys or just buy something that already has all the stuff?
    I'm a company driver in a 2017 international lt. It has dual antennas. Is the factory coax good for rx and also tx with say a 100 watt or so linear? If that coax isn't good enough would a single antenna at the rear of the cab work. Running new coax out through the doors and through the mirrors isn't an option due to it being a company truck and i'll only have it for another year maybe less.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I don't do anything peaked or fancy.
    I have a Uniden Pc76xl that is basic, able to adjust to whatever vehicle or antenna it's in via SWR and so on. It's not a SSB radio. (Don't need it really...) it's probably worth 20 bucks after about almost 30 years since I bought it with poker winnings in the I-20 calhoun shop.
    One thing I do is velcro a external speaker to the dash so I can hear the #### thing when it's worth hearing, when it's not turned down for quiet in a land of bla.
    rabbiporkchop Thanks this.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Can't add ssb to a radio...you would have to just buy another radio that has ssb... Best radio I've had in a long time is the President McKinley...Has all the features of larger case size radios, but compact in size...All I did when I bought mine was turn up the modulation pot and ssb pot (which is right next to the modulation) the radio came to life.. modulation was only at about 75% from factory, and ssb around 3w's. turned modulation up to 100% and ssb to 12w's. paired with a 1x2 and I can talk from one end of the County to the other...
    BrandonCDLdriver Thanks this.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    just go out and buy what you want, but with the lack of cb'ers out there, you'd be wasting your money going full hog on updating beyond out of the box performance.
    IluvCATS Thanks this.
  6. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    With the money you will spend getting your cobra de-tuned and $200+/- for say a 100w blue box amp. Put that money in to a great radio at around $400 - $500 with all those fancy bells and whistles you want and be done.
    FYI running 100w means you will have to hard wire the radio or amp directly to a battery source. Think about that changing trucks every year.
  7. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    My approach was to get a small radio (Uniden 520) putting a couple of watts into a small amp (Italy 203p). For less than $150 invested, it gets me 70 or so watts on AM and is quite effective.
    The radio pulls maybe 2 amps and the amp about 10, so I plug both into 12vdc accessory ports in the cabin without overloading anything.
    I need maximum mobility, so I run my little outfit without any permanent mounts. As a result, I can unplug my stuff from the 12v system and antenna coax in a couple of minutes, put it all in a hand bag I use to store them, and be on my way to another truck as needed.
    I didn't get a radio with ssb because I only communicate with other drivers about road conditions and wrecks etc, and I don't need ssb for that.
    The amp, however, is capable of and is reported to be a fine performer on ssb. Plus, it has a preamp for times you need to pull in a faint signal.
    Lots of ways to talk well out there.
    Slowmover1 Thanks this.
  8. stacks
    stacks Road Train Member
    1,547
    850
    Oct 27, 2011
    Emerald Isle
    Stryker SR 955 hpc
    Timin770 and Samuelh Thank this.
  9. Tensleep440
    Tensleep440 Light Load Member
    113
    63
    Mar 29, 2018
    NE Corner of Texas
    SSB in a rig isn’t practical, but if it is a must, a great SSB rig is an Anytone AT-6666. If SSB isn’t necessary, go for a Stryker SR-447HPC2. Both are excellent radios and have more than enough power to be heard.
  10. Ridgeline
    22,725
    123,401
    Screw the idea of getting a 10 meter super duper rig or an amp, get any radio, get it aligned right then focus on your antenna, power won't compensate for a poor antenna.
  11. volvo244t
    volvo244t Road Train Member
    1,775
    1,779
    Jun 24, 2010
    Bettendorf, IA
    Sure it is. When the skip was rolling with GOOD conditions back in 2015, I'd spend all day on 38 LSB while rolling down the road.
