Decision time
Discussion in 'Ask An Owner Operator' started by godgunscountry, Apr 21, 2014.
  1. godgunscountry
    godgunscountry Bobtail Member
    39
    28
    Jul 25, 2013
    phoenix, Az
    I'm looking at a 2008 prostar 450hp cumm. Isx w/ 500,000 miles 13sp with apu for 42K and a 2009 cascadia with the DD15 450 Hp w/ 10 sp and 600,000 mi no Apu 47K and last 2009 Pete 387 cumm Isx 455 Hp w/ apu. And 620000 mi. For 50 k
    I need a newer truck for Calif. I have to keep it under 50k. Just looking for thoughts on the trucks and or any suggestions. I know some dislike the ISX and some the DD15 but I think its a crap shoot with the emissions on them but cant buy a newer truck right now. I'm looking mainly at fuel mileage. The truck will pull a flat bed from Az to TX or PA then to northwest then back to AZ.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    CK. back with ECM. report, oil ail. last run it on the mach. to ck. blowby.
    godgunscountry Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,556
    13,285
    Jul 6, 2009
    detroit gets better fuel mileage then isx. and is more reliable. FL would probably be more reliable then prostar. it's a crap shoot with prostars.
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    Of topic but needs to be said. There is another option: adjust your business plan so you no longer need to enter California. Rates out there are cheap anyway.
  6. godgunscountry
    39
    28
    Jul 25, 2013
    phoenix, Az
    Spyder thanks for the advice but Cali. Has some good opportunity for me with a direct shipper Ive been working with. About 70% of the loads will have a back haul so more times than not I wont be looking for loads home.
  7. godgunscountry
    39
    28
    Jul 25, 2013
    phoenix, Az
    Thanks for the other responses.
  8. Steeleandsonfarms
    Steeleandsonfarms Light Load Member
    278
    125
    Sep 16, 2012
    Edgerton, OH
    If I had to pick one of the choices, I'd probably go Freightliner. Parts are cheap and readily available. However, a 2010 Volvo 780 is comparable to all those and rides like a caddy. Dd15 with the I-shift if you can find one or the 13 speeds are readily available.
  9. spyder7723
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    I only mentioned it cause so many don't even consider it.
  10. godgunscountry
    39
    28
    Jul 25, 2013
    phoenix, Az
    New in the mix is a 2009 volvo. With a Cummings isx 450 Hp 13 spd 500K miles w apu 51K. Life time mph 7.3. And 8 new tires. Its definately the front runner. Wish it had the DD15 but haven't seen a Volvo with that in it yet.
  11. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    Of those you mentioned you have the option to buy DON'T. Ca is going thru too many changes with CARB and those will not fit their projected plan. Other than that buy and don't go to CA. I no longer go to CA and the only thing I miss is my friends I have out there. when I bought my truck I noticed the wheel base first. I wanted to be able to pull flatbed and need the room for head ache rack. It is a 240 in WB. now have 6 door rack and room for other stuff. Pulled the skirting of the rear half and have storage boxes and apu in their place. Shop around and dont be in a hurry.
