Def and Canada driving
Discussion in 'Questions From New Drivers' started by csw1818, Apr 6, 2014.
  1. csw1818
    csw1818 Medium Load Member
    377
    139
    Feb 6, 2014
    pinehurst, nc
    So what exactly is Def I thought it was something to do with epa to not hurt the environment with the old diesels black smoke but I guessed wrong?
    And Canada driving passport needed or because technically you aren't a tourist do you just get something from the company saying you can drive there? Even with a passenger
  3. Balakov100
    Balakov100 Road Train Member
    3,937
    2,637
    May 10, 2012
    Temple, TX
    DEF = Diesel Exhaust Fluid.
    Not sure how it works/supposed to work exactly.
    Supposed to clean up the emissions somehow :D
    Extra tank on the Truck between 5-15 gallons. Think 'my' Cascadia (Company Truck) has a 13 gal tank.
    I usually put 5-7 gallons every other fillup.
    csw1818 Thanks this.
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    DEF breaks down compounds in the exhaust. You used to just roll up to the border with your CDL and paperwork for the load... now you need a passport, as does any passenger.
  5. vikingswen
    vikingswen Road Train Member
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    DEF has been explained already, but if you have a truck that uses it you better know where to get it. I have a 23.5gal DEF tank and still struggle to make it to Alaska. I carry extra jugs in the cab with me. Yes, it has to be in the cab since it will freeze. Between WA and AK I know of only one cardlock fuel station that sells DEF in Canada at the pump. DEF is like Gold up North and I have paid over $7.00 for a gallon. Walmart and auto parts stores become your friend. I just dumped 9 1/2 2,5gal jugs in my DEF tank and added to more cases in the cab as back up.
    You can get an enhanced drivers license or use a passport to get across the border. Make sure you have no skeletons in your closet since they will do a back ground check on your first crossing and lots of people will be denied entry. Besides your BOLs you will have either an in transit manifest if you will just travel through Canada or P.A.B.S and P.A.R.S and ace manifest when loading or delivering in Canada to the US.
    heyns57 Thanks this.
  6. Balakov100
    3,937
    2,637
    May 10, 2012
    Temple, TX
    In the US most Truckstops have DEF at the Pump by now.
    At least the big chains.
    Loves, TA/Petro, PFJ.
  7. vikingswen
    1,436
    1,990
    Jun 14, 2012
    In the Stratosphere
    That is one of the things I miss most running up North are the truck stops with high speed pumps. In Canada it is one tank at the time, no DEF pumps and showers are not easy to find either. Most places I fuel at are unmanned card locks. The high light of fueling is when your card swipes within the first 10 tries and I get a receipt after fueling.
    Balakov100 and 25(2)+2 Thank this.
  8. Ridgeline
    22,369
    116,053
    Getting into the great country of Canada isn't a problem, it is getting back home that you need a passport, enhance license or FAST card (best one) so they can Identify You.
    tinytim Thanks this.
  9. csw1818
    377
    139
    Feb 6, 2014
    pinehurst, nc
    Well I got into special forces building if anyone is.familiar with military it's SOFC4, special forces, command, communication, control, and computers. Have to pass an extensive background check and its guarded around the clock by armed guards so I think I'll be fine haha.
  10. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    DEF is a system that is used in your exhaust system.
    A hexagonal shaped, stacked filter unit which is coated in various precious metals and catalysts at the end of your exhaust, captures diesel particulates that are harmful to living organisms.
    When these particulates are caught in the filter, DEF fluid which acts as a reagent (urea, and water) is sprayed into the exhaust flow which then reaches the filter.
    Combined with the heat and reagents (DEF), the filter acts as a catalyzer- essentially breaking down carbon, hydrogen and sulfur bonds which hold together partially burnt, or completely unburnt hydrocarbon chains (IE: Diesel fuel, various sulfurous compounds, CO, ect ect) into less harmful substances.
    In short, DPS/DEF systems do help cut down on emissions.
    heyns57 and csw1818 Thank this.
  11. csw1818
    377
    139
    Feb 6, 2014
    pinehurst, nc
    Well that was minorly scientific haha thanks for the explanation
