Last night i started getting a warning beeper and a dash display message that says 'DEF Incorrect - Service Required.' Had a significant loss of power. The company tractor shop says this is possibly a clogged Def filter. They advised not driving it so I shut it down. I have had the Def filter replaced at a company shop (a 15 min job) and thought this can be done by a roadside tech. But the company road maintenance night shift insists that it's a Diesel particulate filter regeneration failure issue that can only be done by a Volvo dealer. And, of course, I'm more than 100 miles from a dealer on an Ar. back road, with a loaded trailer. Any suggestions? Is this a roadside repair, or a tow truck to the dealer issue?
Def issue in '11 Volvo 780 with Cummins ISX
Discussion in 'Volvo Forum' started by fishnman, Apr 8, 2014.
Is it possible you got a bad batch of DEF? How soon after your last filling did it happen? How much is in the tank now?
DEF is very sensitive. You sure you didn't get any sand, road salt, rain water, etc. into the tank?
I fueled less than two hours before the problem occurred. So the Def tank was very close to full.
I seriously doubt that anything got into the fuel. But.. stuff happens, huh? Of course if any of those things got into the tank, there might be a clogged filter.
DEF incorrect could be the def quality sensor took a dump or having a nox sensor going out. many different things could be going on
