Def pump harness conncector
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sktrucker89, Jun 13, 2017.
  1. Sktrucker89
    Sktrucker89 Bobtail Member
    32
    Mar 9, 2016
    Can some one tell me where can i find def pump harness connector for my cascadia 2013 dd13. My trucks showing codes spn4375 05. I tracked the curing process from detroit n it wants me to unplug def pump harness connector n check for damage. But i am unable to locate that connector. Any help will be much appreciated. Thanks
  3. Robd1178
    Robd1178 Light Load Member
    75
    94
    Oct 16, 2015
    If it's an international, they've had issues with the harness. My prostar was At the dealer for almost a week getting it replaced. At least it was covered under warranty though.
  4. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    It's the only connector on the DEF pump. Mounted to the back of the bracket that the DEF tank is in.
    p608 Thanks this.
  5. Sktrucker89
    32
    Mar 9, 2016
    I can see a two pin screw on thingie on that bracket. But in that detroit page they are talking about a 4 pin connector. Is it inside that bracket.
