Def
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Micki88, Mar 9, 2017.
  1. Micki88
    Micki88 Bobtail Member
    I have a 2012 cascadia with a DD15 my def gauge is stuck on full and the tank is full also been like this for the past 3000miles. Any ideas what's going on?
  3. Lon76
    Lon76 Bobtail Member
    11
    12
    Feb 23, 2017
    iowa
    I would say there is something wrong with your system. Should probably get checked out before it derates and leaves you stranded. I take it you filled the def tank drove 3000 miles and the tank is still full. The truck i used to drive had dd13 and used about 2% def for the fuel that was used.
  4. Bike rider
    Bike rider Bobtail Member
    48
    33
    Apr 11, 2016
    I would say there is a problem and you will be heading for a derate situation, our long haul highway trucks go about 5000 miles between fill ups, obviously this depends on DEF tank size, but I would say the truck is not pumping DEF for some reason.
  5. Kenworth 4life
    Kenworth 4life Medium Load Member
    423
    6,711
    Feb 16, 2017
    Augusta, Maine
    Im so glad I don't have this issue!
    SAR Thanks this.
  6. 25(2)+2
    18,756
    45,825
    Sep 18, 2006
    the road less travelled
    The guage may be wrong, and the first segment usually does last longer, I can believe it showing full yet at 3000 miles.
    We usually fill at the shop, without a meter. But I'd start topping it off, if you are allowed to, when you fill up with fuel, to get an idea of how much it is using.
  7. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    Did you just buy the truck? I'm only asking because if you did maybe the previous owner bypassed the DEF system and just didn't tell anyone.
    Olson Diesel LLC Thanks this.
