Defining a Load Properly
Discussion in 'Heavy Haul Trucking Forum' started by NewbieKnowLittle, Jan 24, 2022.
  1. NewbieKnowLittle
    NewbieKnowLittle Bobtail Member
    Jan 24, 2022
    Hello guys,
    I am seeking some unbiased, but experienced advice on a haul.
    Dimensions:
    Length: 40'
    Width: 11.5'
    Height: 10' (over estimate)
    Weight: 16,000lbs (over estimate)
    Pickup Location: New Orleans LA
    Dropoff Location: Berkeley CA
    I have a 1986 Alubat Ovni 37 all aluminum expedition style sailboat. Its designed to push through ice and dry out on its own bottom- built strong. To dry out on its own bottom, it is a centerboard type boat- meaning there is no keel and it can be loaded onto standard dunnage- perfect for a standard step deck or lowboy haul. It does not require a specialized yacht trailer.
    The problem I am having is that whenever I reach out to shippers, they seem to get very focused on this being a boat and sometimes dont want to haul it. But its not your normal type of boat and it seems hard for me to explain that to someone who has no experience with this style of craft.
    Do you have any suggestions for the terminology or information I might provide in initial query email that may help with this?
    The next problem is that the quotes that I am getting seem far above what I am finding as posted per mile rates for the trailers they are suggesting. I am most commonly being told I need the RGN Lowboy. Despite that it fits dimensionally on the much less expensive step-deck. I am being told that they want to keep the center of gravity low- sure makes sense. But its a sailboat and has 50% of its mass (called ballast) located directly in the center of the bilge (bottom framing of the boat)- a mass of lead pigs encapsulated in resin sitting in the bottom center of the boat and completely welded in- so it would be hard to get the mass any lower and centered than that.
    Do you have any suggestions of what I might say to explain this part?
    I had one company say that drivers of step-decks are not experienced enough and that is why I need an RGN lowboy- can you help me understand why they wouldnt assign a driver and trailer that best fits the needs of the load rather than just upcharge me for the RGN?
    I have attached the photos that I am sending in query emails for your comments and considerations. IMG_4220.jpeg IMG_4216.jpeg IMG_4215.jpeg
    singlescrewshaker Thanks this.
  3. IH Truck Guy
    4,578
    52,645
    Mar 2, 2008
    Purgatory
    How about a pic of the actual boat that you want hauled.
  4. NewbieKnowLittle
    Jan 24, 2022
    The last two photos are the exact make and model. The top photos is simply a couple years newer- but same company and design.
    This is the exact boat, but of course the mast would be taken down and prepped for shipping: IMG_3289.jpeg
  5. REO6205
    REO6205 Road Train Member
    13,168
    60,490
    Feb 15, 2014
    California.
    You're looking for a cheap transport when you should be looking for somebody that knows what they're doing. You spent a lot of money for a good boat. Don't pinch pennies by taking a chance on somebody who's never hauled a boat like yours before.
    Part of the cost of specialized hauling is paying for things that don't happen...wrecks, scrapes, top outs, shutdowns because of permit violations, things like that.
    I'm moving this to the Heavy Haul section. The members there will be able to give you advice on how to proceed.
  6. NewbieKnowLittle
    Jan 24, 2022
    Thank you! I really appreciate that.
    I dont feel I was looking for the cheapest answer, but just trying to get a better understanding of what to expect since posted rates available online and the rates quoted were so far off.
    I tried to communicate my questions clearly as I think I am having communication issues with the shippers I have contacted thus far. Sometimes its as simple as not knowing the terminology to use.
    Is this load considered a heavy haul because of its size then? Its certainly not heavy compared to trailer and load ratings posted on the heavy haul rates.
  7. REO6205
    13,168
    60,490
    Feb 15, 2014
    California.
    The height and width will help determine what kind of special permits, pilot cars, and routing will be needed if any.
    People who specialize in hauling oversize loads will know the permitting process which in itself can be a can of worms to the uninitiated.
    They're also more likely to have the insurance required.
    Go with the pros. They're worth it.
    truckdad, cke and IH Truck Guy Thank this.
  8. 062
    062 Road Train Member
    6,274
    33,779
    Oct 20, 2013
  9. IH Truck Guy
    4,578
    52,645
    Mar 2, 2008
    Purgatory
    The trailer you really want is a stretch RGN to accommodate the 40' length.
    That will also allow for cribbing and blocking that will increase the height.
    Are your measurements exact or guesstimates??
    cke Thanks this.
  10. LoneRanger
    LoneRanger Road Train Member
    3,687
    9,580
    Jun 3, 2018
    It’s considered over size which falls into the OS/OW category.
    Remember the guys that are willing to haul this aren't cheap by any means. Sure you’ll get that one guy who’s willing to haul it cheap but your going to get what you paid for.
    AModelCat, beastr123 and cke Thank this.
  11. nikmirbre
    nikmirbre Road Train Member
    5,534
    10,148
    Jul 27, 2011
    High Point NC
    Definitely a stretch RGN…. I have 34 in my well and probably wouldn’t attempt to haul that. I’d also put in on a boat trailer.
    truckdad and cke Thank this.
