Detroit 12.7 fuel in coolant
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by henboy1, Sep 1, 2019.
  1. henboy1
    henboy1 Medium Load Member
    331
    139
    Mar 26, 2011
    stockbridge
    I was checking my fluids this morning and I found some diesel in my coolant on this 2000 century . This must have just started. I am wondering if I will be able to make 2000 miles to the house . I assume this is a lining or head gasket issue. Anyone ever had this issue? Original motor and not touched
  3. mladen86
    mladen86 Medium Load Member
    303
    269
    Aug 23, 2012
    Chicago,il
    I had same problem but different engine,volvo d12.
    My red coolant became almost water like clear,coolant tank got darker and there was some brownish build up on the inside wall of the tank.
    I had to replace injector cups
  4. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Wow. Where you able to drive the truck to make it home? How many miles did you drive after that ?
  5. mladen86
    303
    269
    Aug 23, 2012
    Chicago,il
    I actually drove like that for 3 weeks. Truck was running fine,no problems whatsoever,no change in engine performance
    henboy1 Thanks this.
  6. AModelCat
    159,075
    That fuel will start to eat away at your rad hoses over time. Most likely culprit would be an injector seat. Suppose a cracked head could be possible too but not sure how close the fuel galley is to the coolant ports. You're definitely going to have to flush the system regardless. Personally I wouldn't run it.
    Dave_in_AZ and henboy1 Thank this.
  7. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    I would drive it home,just keep checking it.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    injector cup seals on mine. can drive for quite a while. but will get worse. mine pressurised the system so much that the reservoir cracked open.
    Dave_in_AZ Thanks this.
  9. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Great info guys . Thx
  10. Rideandrepair
    17,337
    56,255
    Aug 8, 2015
    I’d run it home. Not getting hung out at the mercy of thieves. The head needs to come off, to change injector cups. Very good chance, damage to cup(s) is minimal. New seal kits, ( o rings) are fairly cheap.A new graphite crush fire ring seals up minor damaged cups. along with a big fat o ring. Some claim it’s a bandaid, My bandaids held up for 3 yrs+. Otherwise if heads got to come off, might as well do an inframe.
  11. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Wtf. Maybe I put diesel in the reservoir a couple of weeks ago, if I can remember. I always keep a job diesel in a 1 gallon oil bottle. And I use this diesel to Prime the truck every time I do p.m. . What if I mistakenly put diesel in my coolant reservoir , and how can a mechanic distinguish this without having to take the heads off?
