Detroit 12.7 with 14l Head
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Detroit series60, Dec 9, 2020.
  1. Detroit series60
    Detroit series60 Bobtail Member
    10
    Hello I am going to do an overhaul on my 12.7 series 60 Detroit and I have a remanufactured (less than 20k miles) Detroit s60 14 liter head laying around. So can I put the reman 14L (ddec5 ) head on the 12.7L (ddec4)engine. I heard that it will bolt up but I would have to use : 12.7 camshaft, 12.7 rockers, 12.7 jakes, the 14L injectors.
    Can anyone tell me if this seems right? I’m assuming I would adjust the overhead based on the 12.7 specs? Also if I use the 14L injectors will it work with the 12.7 DDEC 4 ecm. If it will work do I just cut the connector off the 14L injector harness and solder them to the original 12.7 injector harness ? Btw the 12.7 is non egr and the 14L head is egr
  3. little cat 500
    2,055
    1,099
    Jan 17, 2010
    Abbottstown PA
    im not 100% sure but i dont think the injectors will work with the dd4 ecm as far as bolting the head on yes it will fit the 14 liter rockers and jakes should works fine use the 12 cam
    ibcalm19 Thanks this.
  4. Detroit series60
    10
    Ok thanks , I wonder do I have to change the whole ecm or what other options do I have
  5. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    I just read your post on the n3 injector with the dec4 ecm. As Little Cat 500 said, I don't know if they will work with the dec4 ecm. If they do I would do the wiring at the injector connector like you have in mind. All the best to you.
    Detroit series60 Thanks this.
