Detroit 12.7l burning oil and excessive blowby
Discussion in 'Ask An Owner Operator' started by rankd1, Dec 27, 2021.
  1. rankd1
    rankd1 Light Load Member
    70
    62
    Sep 8, 2014
    I have 12.7 60 series with 1.5 mil + that runs decent and has good torque but recently taken on a rank odor like fresh asphalt. It is really pouring exhaust out of tube. It has been using about a gallon of oil every couple thousand miles (weekly). It does have some small leaks, nothing new, but not terrible.
    Question; anything I can do to extend its life without major? It did have a new head put on @ 555,000 due to screw on jake coming loose but has been a great runner.
    jamespmack and feldsforever Thank this.
  3. AModelCat
    159,013
    Sounds like its worn out. If its never had any major work besides the head you got your money's worth out of it.
  4. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    Have you had the bullgear serviced?
    Have you put bearings in?
    Otherwise keep adding oil until you can't take it anymore...
  5. Diesel Dave
    8,720
    24,969
    Jan 20, 2010
    Hesperia, Ca.
    Throw a gallon on WallyWorld (Walmart) Supertech 85/140 gear oil. Seems the engine is worn out. The gear oil should stretch it out, I’ve even read that some have use 2 gallons of gear oil. Use either, 85/90 or 85/140, you have nothing to loose.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    better do like them cat boys. run that blow by hose 2" off the ground. this will keep the oil from blowing all over your truck. also get the bull gear job with the inframe job
  7. rankd1
    70
    62
    Sep 8, 2014
    Yes I certainly got my money out of it, its just that it still runs decent.
    Rideandrepair and feldsforever Thank this.
  8. rankd1
    70
    62
    Sep 8, 2014
    No work done on it. I guess keep adding oil until I either fix or replace - would like a newer machine its a 98 9200i.
  9. rankd1
    70
    62
    Sep 8, 2014
    How about Lucas stabilizer, heard that may help?
  10. rankd1
    70
    62
    Sep 8, 2014
  11. rankd1
    70
    62
    Sep 8, 2014
    Never heard of adding gear oil, is that i or 2 gallons to the oil change?
    Rideandrepair Thanks this.
