Detroit 14L Turbo
Discussion in 'Western Star Forum' started by Lonestar, Jan 20, 2015.
  1. Lonestar
    Lonestar Bobtail Member
    30
    May 17, 2008
    Totonto Onatario
    We are running an old woods truck with DDEC 4, the VGT turbo is leaking air around the actuator rod where it enters the turbo, is it possible to disconnect the rod , set the rod to a position between maximum and minimum boost, cement it in place with high temperature sealant and operate the turbo with the blades in a set position. The air actuator assembly is in working condition with no leaks.
    The turbo is good mechanically for end play etc and makes no noise. Is there any reason not to try this??
  3. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    I think you should repost this in the garage. There's a lot of guys there who would know i'm sure, I think they just haven't seen it.
  4. Lonestar
    30
    May 17, 2008
    Totonto Onatario
    Thanks, I have re posted the question.. We were trying to save the cost of a new turbo for this application.
