Detroit 60 series 14l pulling the head…...
Discussion in 'Freightliner Forum' started by nikmirbre, Mar 12, 2014.
  1. nikmirbre
    nikmirbre Road Train Member
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    Im trying to understand, what is the problem with pulling the head? Do people not want to pull it because its a lot of work or because its real tedious work?
    Ive got a 07 columbia w/580k on it and I still have warranty on it.(Select truck warranty) I was loosing coolant and could not tell from where but I knew it was burning in the exhaust. When I shut it off, upon start up it was smoke white real bad, but never really smoked while driving(white)….It ran hot while sitting idled but not while driving…..
    I dropped it off @ freight liner friday and they called me yesterday wanting my permission to pull the head. So I don't know much but I'm assuming they checked everything they could w/out having to take the cylinder head off…… Its almost like pulling the head is forbidden or something…whats the deal??
  3. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    $$$$.... 1000-1500 in labor alone.... parts minimal-new head bolts-gasket- gonna be around 2000-2500 when all said n done
  4. nikmirbre
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    do they drain oil or any fluids when puling the head(or before pulling it)?
  5. nikmirbre
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    Ok so its a timely process, not just unscrew a few bolts then…...
  6. RAGIN CAJUN
    RAGIN CAJUN Light Load Member
    198
    116
    Jun 20, 2013
    I would try n get a second opinion before they pull DA head off...its a lot of stuff they have to take off..DA heads sit on top of Block..example its like they doing heart surgery with out scanning your heart..that's why people trip about pulling the head...people don't normally pull them unless there sure...sounds like to me it ran hot and the coolant is going pass head gasket,and they have to pull the head to look at the gasket..but normally if its bad bad..a oil sample can tell if water is in it...I'd go that route 1st..but don't wait to long ...if that coolant get n between DA block n bend them rods u may b looking at a new engine...if you have the money get it done at freightliner...sound like they checked everything else out and this is the only last option...normally when coolant runs low and engine runs hot they check the entire coolant system from fan,to thermostat,coolant lines for leaks,pressure test,water pump,and more when all other options are exhausted that's when they pull DA head...hope this helps...
  7. nikmirbre
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    Yes its at freight liner dealer here in charlotte...
  8. that65
    that65 Light Load Member
    185
    84
    Jan 16, 2012
    Lincoln,Ne.
    I would of took it to Detroit, hands down...
    losttrucker Thanks this.
  9. nikmirbre
    5,376
    9,583
    Jul 27, 2011
    High Point NC
    Its under warranty…..freightliner had to do it
  10. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    Freightliner owns Detroit and if engine warranty don't matter who does it as long as the are Detroit certified but for me I think Detroit is higher priced then freightliner but I am sure they are all overpriced
  11. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Hey nick. Head removal on your motor isn't all that difficult. However it is time consuming. They will ask permission just because of the cost. The one piece head is heavy so you need a lift if some sort. There are 32 head bolts so that takes time. They will check surfaced and rework if necessary if possible at all. A job like that could easily run upwards of $6k. Be glad you have warranty!! There are a couple ways to check the head and gasket. Head removal, they drain the coolant. The other way is to drain the oil, remove oil pan and pressurize radiator looking for leaks past the cylinder liners. This is done if you are finding water in oil. Another culprit on the 14l is the egr cooler. That would be my first guess. They can remove and pressure test it.
