Detroit 60 series cam trouble
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Juanz254, Oct 25, 2021.
  1. Juanz254
    Juanz254 Bobtail Member
    Hello,I am swapping out my cam in my Detroit. The issue seems to be the bolt to the timing will not fit in my new cam. Both cams are off a Detroit 60 series 12.7 but they have different part numbers. Mines is 23521680 and the new one is 23528309. What could possibly be so different on these two? Could I just put a bigger bolt because both cams are identical, it just that bolt that goes to the timing goes right through the new cam
  3. little cat 500
    2,055
    1,099
    Jan 17, 2010
    Abbottstown PA
    there are 2 diff bolts 18mm 20mm you have the wrong cam
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    different part numbers would tell me thats the wrong one then especially if different bolts. but hey thats me
  5. little cat 500
    2,055
    1,099
    Jan 17, 2010
    Abbottstown PA
    yea the 8309 cam takes a 20mm bolt
  6. little cat 500
    2,055
    1,099
    Jan 17, 2010
    Abbottstown PA
    1680 is a dd3 cam 8309 is dd4
