Detroit 60 Series radiator fan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dhhobie2, Mar 17, 2017.
  1. dhhobie2
    dhhobie2 Bobtail Member
    4
    I Have a 2000 Freightliner Century Class with a Detroit 60 series motor. I replaced the belts on the radiator fan, when I fired it up noticed the fan was on constant.is it supposed to be on or is there a clutch on the fan? so they run on air?
  3. passingthru69
    Do you have it on a/c or defrost. If so it will kick the fan on. With key off, fan will be locked in. Turn key on and see if fan free spins, if not check the air line to the fan selinoid and check the wires to the selinoid
    Ezrider_48501 Thanks this.
  4. perez05pr
    perez05pr Bobtail Member
    49
    7
    Oct 20, 2010
    ohio
    i have the same problem! fan is constantly on..already replaced the selenoid, it has 12 volts on 1 wire but no groung to the other! i heard the groung is controlled by the ecm..
