detroit 60 series seems to be running flat or no power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nhramember, Apr 2, 2012.
  1. nhramember
    nhramember Light Load Member
    86
    25
    Apr 2, 2012
    Here is my problem I have a 12.7 detroit 60 series and it seems like it just doesn't have any power. The turbo whistle is very faint. I have a little bit of black smoke out of pipe when i accelerate onto the interstate. I had a brand new crate model put in 2008 and they didnt change the turbo. I believe this is the original turbo. I bought the truck used in 2001 and never replaced the turbo would it be worth it to by a pdi turbo or a factory turbo? I havent did any mods to the motor.
  3. fastsix62
    fastsix62 Light Load Member
    75
    17
    Feb 4, 2011
    fort worth, tx
    Could be as simple as a clogged up fuel filter. That is the problem I ran into.
  4. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Yep, the turbo would be bad. I had a 12.7 I ran for 7 years and every 200k miles I had to put a new turbo on the truck. I'd suggest getting a boost gauge on it if you really want to know if it is or not. But a turbo for them is only $850 and it wouldn't hurt to change it out now before it went BOOM !!!
    Mommas_money_maker Thanks this.
  5. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    I dont know much about detroits but I hear some had EGR problems.
  6. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    The 12.7 was a pre-egr engine. The 14L was the one with the EGR
  7. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    Thats right! the 12.7 dont need no stinkin' egr! LOL I believe you have a turbo issue and like SHC is saying fix it now or it will go boom. I have same engine but mine has a fresh rebuild and new turbo and it kicks butt
  8. SHC
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    To be honest, the PDI Stage 1 turbo is only $975 so if I were you, I'd go with that over a rebuilt stocker at $900 from the dealer.
    peanut 21 Thanks this.
  9. last 1
    last 1 Medium Load Member
    439
    184
    Nov 29, 2009
    Some 12.7s had egrs
  10. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Especially if the turbo is a waste gate version. You can get a Borg Warner non wastegate turbo for $600-$700 and have far better results than the stock turbos. And at those prices, even have a spare one lying around! What model of BW turbo is dependent on the hp your Detroit is set up for.
  11. Dino1968
    Dino1968 Light Load Member
    How long has it been since your air filter has been changed/checked? If it can't get air, it can't make power.
