Detroit DD15 coolant filter plugged
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Heavyd, Jul 12, 2014.
  1. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Hey guys we have a few customer with DD15 engines and we are finding the coolant filters completely plugged with what looks like mud/dirt or some kind of sediment during an oil change. Coincidently we did two services today and both filters had this brownish/greyish looking type of mud that completely plugged up the pleats in the filter. I did not get a picture, but the one filter was actually hard to get out because it was so plugged up. Both of these trucks are totally unrelated to each other and in different applications. We have seen filters like this on somewhat of a regular basis. There is no sign of oil in the reservoir and the customers do not complain of coolant loss or levels going up. Anyone seen or heard of this before?
    msh and BeenJammin Thank this.
  3. Duramaxxed
    Duramaxxed Light Load Member
    155
    60
    Jan 2, 2012
    Bourbonnais, IL
    Stop leak looks like brown mud in a coolant filter.
    makterna, Heavyd and 25(2)+2 Thank this.
  4. 25(2)+2
    18,749
    45,401
    Sep 18, 2006
    the road less travelled
    Maybe someone topped off the AF with something incompatible with the coolant already there. I'm very careful not to do that.
    86scotty and Heavyd Thank this.
  5. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    Conklin has a stop leak product called dike, I will agree with above posters. First place it goes is the coolant filter, and it has a brown texture to it, with green coolant and even more in elc. It totally clogs the coolant filter quickly. In applications without a coolant filter, it's a pretty good product. Especially in the liner oring area.
    DetroitDudeBro and Heavyd Thank this.
  6. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Do you have access to DDSN? If you do, check out 13ts19 service bulletin. There is silicate additive dropping out of the coolant, causing the gel like sludge. Pressure test the pressure cap, drain coolant from the block and radiator, remove the water pump and inspect for damage. If none found, flush system, r&r the filter and add new coolant
    KB3MMX and Heavyd Thank this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,513
    Dec 29, 2008
    Northridge, CA
    hi. do you have 13ts19 service bulletin ?
  8. Sphillips38
    Sphillips38 Bobtail Member
    41
    7
    Oct 18, 2016
    24477
    I just bought a western star with a dd 15 in it.Ive never driven a truck with a detroit engine in it.What temp should i ne running in the hills.Might wanna check my filter
  9. Smokestacksno10200
    Smokestacksno10200 Bobtail Member
    I have a 2015 westernstar with a dd16 same thing happend to it and when temperatures dropped sownd to -30 it wouldn't even rev up i putva new filter inbitvtgen a month later it started to feel sluggish again so checked out the filtervand it was plugged solid i called ws dealer thinking a bad head gasket and they said they're having lots if problems and to just takectge filter out and as long as coolant is clean then shouldn't have any problems so i took it out and ir seems to run alot better im not sure why but I'm sure theres a reasonable explanation
  10. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
