Detroit Diesel 71 - 92 series fans
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 8x8, Mar 6, 2013.
  1. 8x8
    8x8 Light Load Member
    87
    44
    Jun 3, 2007
    Please NO DD 2stroke bashing, if don't like em SAY NOTHING !
    Anyone out there running one as a working truck ? Or Fans of them please post
    I know we have a few here in ND oil fields, plenty still powering rigs and generators
    I'm a Heavy Haul - Rig Mover been running companies KW C500 / T800's Cats & Cummins, fuel mpg is not sure a big concern. None of the current Acerts or ISX's get an more than 3.5 mpg even when they are empty.
    So after much searching for a heavy spec affordable truck I've bought Autocar w/ silver 8v92TA.
    I plan gear it for 60 - 65mph @ 1900 rpm in direct ( 1:1) for max speed When loaded, hope to have around 600+ bhp once upgraded, still researching spec's for high power output
    shmuck359, jamespmack and Oldironfan Thank this.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,226
    Aug 24, 2011
    Sunny Tampa Florida
    Ran a truck with one it and did plenty of heavy hauls with it, worked well for me.
    Oldironfan Thanks this.
  4. freightlinerman
    freightlinerman Road Train Member
    1,287
    535
    Mar 4, 2011
    Florida
    Ehh, 8V92T is not the best choice. 6V92T, 8v71, 12v71, 6L71, etc. The 8V92T's from my experience got horrid fuel mileage and have mechanical issues, depending on how the owner took care of them previously. Cooling, after market parts, the wrong oil(15W40 instead of SAE 40) didn't help either.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,416
    Sep 7, 2011
    Pelham N.C.
    Just feed it rod and main bearings every 150000 miles. When right they will RUN.
    x1Heavy and Oldironfan Thank this.
  6. aiwiron
    5,927
    5,226
    Aug 24, 2011
    Sunny Tampa Florida
    Loads I hauled averaged over 75K and the engine ran fine, gross around 110-125K.
    If it can pull that then it was a good motor
  7. freightlinerman
    1,287
    535
    Mar 4, 2011
    Florida
    I have an 8V71N and a 6V92T both in my bus collection, both equipped with 740 Allisons.
  8. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,484
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    Ran a 475hp one for a while hauling grain, it wasn't in the same ballpark with the big cams and mechanical 3406s we have now.
    tommymonza and Oldironfan Thank this.
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,561
    Jul 15, 2006
    El Chuco, Tejas
    Good old 2 strokes. They could rev at 2100 all day and never miss a beat.
    FWIW, the engine sound from the Rubber Duck's Mack was not of the Mack engine it was equipped with but of a 8V71 as the director felt that the 2 stroke sounded "tougher" than the 4 stroke Mack.
    Out in Horizon, TX near my company's terminal there's an old Autocar tow truck that doesn't appear to be used very much. I'm guessing early to mid 70's vintage. Would be a neat restoration project.
    Oldironfan and aiwiron Thank this.
  10. Hammer166
    6,948
    23,901
    Aug 18, 2007
    ~8600+' and loving it!
    I occasionally ran a mid 70's KW with a 475 and a 13 over. Couldn't pull with the 425 Cats, but on flat ground with her legs stretched, they never stood a chance. (Neither did your eardrums!):biggrin_2559:
    Oldironfan and 25(2)+2 Thank this.
  11. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    i think they had two silver 92 one had more Hp than than the one, also had a black painted one with yellow flames on the intakes . my friend had one and run it a million miles with no major problems. like the one fella said they are a little loud.
